B16A2 LSD tranny fluid...what do you use/recommend?
Old Feb 19, 2004 | 07:32 PM
Ishtar's Avatar
Default B16A2 LSD tranny fluid...what do you use/recommend?
Hey guys, its time for me to change the oil in my tranny. I currently have Redline in there but cant find it anywhere and need to change it soon. So dont really want to wait for it to be shipped in. What else can I use that will work best in the B16A2 LSD tranny? Will I need to get some friction modifier (i.e. ford posi modifier)? Any and all input is greatly appreciated. Please note: Brand Name and Weight.
Thanks!
Old Feb 19, 2004 | 07:46 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: B16A2 LSD tranny fluid...what do you use/recommend? (Ishtar)
this is a good ? but i was told for my lsd tranny to use gm sencromesh( and yeah i know i spelled it wrong)
Old Feb 19, 2004 | 08:34 PM
Newman's Avatar
New User
I've had 6 differnet LSD transmission in any of my cars at one time or another, and with our other shop cars that have LSD transmissions, always used Honda MTL and have never had any problems with shifting or grinding. Some people recommend some expensive Kaaz gear oil or some other JDM **** (heh) or something else. But if you stick with OEM gear oil, you can't go wrong.
Old Feb 19, 2004 | 08:51 PM
mrctr's Avatar
honda....
Old Feb 19, 2004 | 09:58 PM
sesshona's Avatar
Default Re: (mrctr)
motul anything...
Old Feb 19, 2004 | 10:18 PM
shermanyang's Avatar
Default Re: (sesshona)
my buddies and myself have been using Honda Automatic Transmission Fluid for years now. A mechanic at the shop where we got our LSDs installed suggested that we try using automatic transmission fluid as it has better lubercants and heat disappating properties than regular oil or manual transmission fluids. we've been using it ever since and have had no problems what-so-ever.
Old Feb 19, 2004 | 10:45 PM
esoterEK..'s Avatar
Default Re: B16A2 LSD tranny fluid...what do you use/recommend? (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">I've had 6 differnet LSD transmission in any of my cars at one time or another, and with our other shop cars that have LSD transmissions, always used Honda MTL and have never had any problems with shifting or grinding. Some people recommend some expensive Kaaz gear oil or some other JDM **** (heh) or something else. But if you stick with OEM gear oil, you can't go wrong.</TD></TR></TABLE> i even try the GM stuff i went back to HONDA MTF
Old Feb 21, 2004 | 08:56 AM
Ishtar's Avatar
you guys are sure with the Honda MTL? I had purchaced some when I did my swap and had pretty crazy clunking sounds coming from the LSD. Thats when I purchased some redline and she calmed down...
The Honda MTL does not need a friction modifier? it is suitable for LSD? I will try it out again and see what happens. Thanks for all of the replies so far!
Old Feb 21, 2004 | 10:10 AM
spoon_ek9's Avatar
depend on what kind of LSD you have. i recommend Neo MTF for gear type lsd. if its a clutch type, Neo MTF + their friction modifier.
Old Feb 21, 2004 | 10:15 AM
King Tut33's Avatar
Honda MTF in my JDM S80 LSD tranny works great.
Old Feb 21, 2004 | 11:18 AM
fOmaNPu's Avatar
Default Re: B16A2 LSD tranny fluid...what do you use/recommend? (King Tut33)
I use Honda MTF, works fine.
88-B16-Civic
Sep 18, 2006 09:41 AM
gooseman
Sep 12, 2006 09:51 AM
EGTHU6
Jul 8, 2004 09:53 AM
turbod92hatch
Feb 25, 2003 10:09 PM
