Height/ Koni Yellows
Old Feb 19, 2004 | 07:24 PM
onramp's Avatar
Default Height/ Koni Yellows
Searched! Nothing!
With my Neuspeed Koni Yellows set on the same height ( 1 from bottom), the rear sits approx. 1" higher in the rear. I want to equalize it a little, by lowering the rears to the lowest setting ( 1 lower than the front). I know that corner balancing is the way to go, but honestly I don't have the means. Have some of you all done this? If so did it noticably negatively effect the handling? I hate the way my car sits compared to other suspension kits I have had before. OBTW I have Neuspeed sports currently (the race were a little much for my town).
Thanks in advance.
Old Feb 19, 2004 | 07:53 PM
onramp's Avatar
anyone?
Old Feb 19, 2004 | 08:10 PM
DsITR's Avatar
Default Re: Height/ Koni Yellows (onramp)
nevermind..
Old Feb 19, 2004 | 08:19 PM
onramp's Avatar
Thanks for your response, but no, I am asking if it would upset the handling balance terribly (or if it is not recomended), if I lowered the rear to a lower setting than the fronts to balance out the dispostion.
Old Feb 19, 2004 | 08:32 PM
DsITR's Avatar
Default Re: (onramp)
what perch are the front springs on?
IMO the change in height is not enough to *seriously* effect handling. The only adverse effect I could see is bottoming out.
I would IM user CRX Lee he works @Koni and helped me choose my setup.
If there is an adverse effect It could also be counteracted by changing tire pressures, and adjusting rebound.
If you are that concerned w/handling to not make that small of a change, you should also be considering where you place things in your car, and how much gas you fill up w/etc.
herrgolf
39
Aug 24, 2017 10:30 PM
integranator
Jan 4, 2003 07:18 PM
Razor
May 7, 2002 08:11 PM
Razor
Apr 6, 2002 02:52 PM
Greyout
Dec 25, 2001 11:07 PM
