2.5 inch collector and stock cat?
Old Feb 19, 2004 | 06:05 PM
JDMluvR's Avatar
Default 2.5 inch collector and stock cat?
Sorry for the noob question. I have a Mugen header and a Buddy Club Spec III on the way. I just want to know if it will all match up, or do I have to buy a different cat? This is just for now, I might run a test pipe later. Thanks for any help guys/girls. Again sorry for noob question
Old Feb 19, 2004 | 06:11 PM
itr 00 0108's Avatar
Default Re: 2.5 inch collector and stock cat? (JDMluvR)
My advice would be to spring for the cat now from SMSP and he will give you everything you need for it to hook right up.
Old Feb 19, 2004 | 06:18 PM
JDMluvR's Avatar
Default Re: 2.5 inch collector and stock cat? (itr 00 0108)
Thank you, I will look into that. Do you have a link I can look at? But for now will it connect at all?
Old Feb 19, 2004 | 07:52 PM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMluvR &raquo;</TD></TR><TR><TD CLASS="quote">Thank you, I will look into that. Do you have a link I can look at? But for now will it connect at all?</TD></TR></TABLE>
JDM length header won't work with an OEM cat and that Spec III.. you need a shorter cat, such as SMSP's carsounds or a test pipe..
good choices though.. I have the same exhaust.. better order some earplugs while you're ordering your cat/testpipe..
Old Feb 19, 2004 | 08:20 PM
Default Re: 2.5 inch collector and stock cat? (mstewar)
SMSP is your contact point. High flows are going to run you around 200 bones.
prelude2.2
Jan 8, 2013 10:02 AM
dohcFTW
Nov 1, 2007 05:05 PM
tegdude227
Feb 22, 2006 09:48 AM
handa
Apr 28, 2005 01:31 PM
itr0045
Feb 6, 2002 05:59 AM
