ATTN: all drivers with 16" wheels!!! tire rubbing problem
Old Feb 19, 2004 | 04:57 PM
stockLS's Avatar
Default ATTN: all drivers with 16" wheels!!! tire rubbing problem
i just put 16" kosei k1's on my 98 ls lowered on eibach sportlines and im having problems with a little tire rub. i have them wrapped in kumho ecsta supras (sp) 204-45-16. my question is... should i go with a smaller tire or get aftermarket adjustable shocks/struts? are there any other options/routes that i can take? have any of you had problems with this... i was thinking kyb agx , or tokico out of these which do you prefer??? any help will be appriciated!
Old Feb 19, 2004 | 05:05 PM
Creep's Avatar
Default Re: ATTN: all drivers with 16" wheels!!! tire rubbing problem (stockLS)
No, I wouldn't go with a smaller tire.
When are you rubbing? Over dips in the road? Shar turns? Up front?
In the back?
Old Feb 19, 2004 | 05:17 PM
Jer'rome's Avatar
Default Re: ATTN: all drivers with 16" wheels!!! tire rubbing problem (Creep)
thats weird, im dropped 3 inches and on 16" was the best thing ive done yet!!, koni yellows and drop zone sleves
Old Feb 19, 2004 | 05:58 PM
Chrisv006's Avatar
Ive droped about 3in...Koni Yellows RS*R Race springs..
Running 16x7 Rota's with 205/40 - 16 tires...Never a problem at all...
-Chris
Old Feb 19, 2004 | 07:20 PM
Sukebei Oni's Avatar
Default Re: ATTN: all drivers with 16" wheels!!! tire rubbing problem (Chrisv006)
do you know the offset of your wheels?
Old Feb 20, 2004 | 07:52 AM
kineticgsr's Avatar
Ive heard the Kosei's rub, i beleive they r 16x7.5 other than that 16x7 all day long ok
where are they rubbing
Old Feb 20, 2004 | 12:12 PM
stockLS's Avatar
Default Re: ATTN: all drivers with 16" wheels!!! tire rubbing problem (kineticgsr)
they rub around turns aswell as decent size bumps in the road! i am on stock shocks will this help the problem if i get aftermarket adjustable ones... i think its rubbing on the inside! not the outer finder wall
Old Feb 20, 2004 | 12:14 PM
WhoNeedsBoost's Avatar
whats the offset on the rims?
Old Feb 20, 2004 | 12:22 PM
stockLS's Avatar
Default Re: ATTN: all drivers with 16" wheels!!! tire rubbing problem (WhoNeedsBoost)
im not sure the offset they came off of a crx hf. the wheels are 16x 7.5 they are supposed to be 43mm i will have to find out more tonight! any other suggestions/ideas in the mean time!
Modified by stockLS at 4:34 PM 2/20/2004
Old Feb 20, 2004 | 12:36 PM
DK4200's Avatar
I have a 98 LS with 16's and 205-45-16 Kuhmo's and no rubbing here... its probably because your rims are 16x7.5 instead of 16x7
Im also dropped on Eibach's Pro-kit
Old Feb 20, 2004 | 12:50 PM
TegLove's Avatar
Default Re: ATTN: all drivers with 16" wheels!!! tire rubbing problem (DK4200)
im not rubbing here and im running 17" wheels. And also dropped like 2 1/2"
i wouldnt go with a smaller tire though. I say raise the car some.
Old Feb 20, 2004 | 02:52 PM
kineticgsr's Avatar
That sounds right( 16x7.5 43mm offset) ... roll the fenders to get clearence.
it should be rubbing just a little... find out where and see what need to be done.
that wheels is common enought at someone has run into this b4
Old Feb 20, 2004 | 06:09 PM
DC2_Integra's Avatar
do u have a camber kit installed also?
Old Feb 21, 2004 | 07:59 AM
stockLS's Avatar
Default Re: ATTN: all drivers with 16" wheels!!! tire rubbing problem (DC2_Integra)
its only rubbing in the rear and i have the rear camber kit installed! i am ready to purchase my front kit soon.... i also found out that the wheels came off of a 99 civic si so thats probably my problem ... the difference in the offset! anyone know what the offset is for that car? i was told like 38mm. if this is indeed true i will need to get spacers but i still dont think that will solve my problem!
Old Mar 3, 2004 | 10:25 AM
xTravBx's Avatar
Hey - I saw that you are selling these in the FS forum, though I'm too new to post in there. I dont know if you still are checking this thread, but I live in OH and would love to get those wheels from you. Please email me
seventeenforever@hotmail.com - thanks
Old Mar 3, 2004 | 12:16 PM
bo0sted's Avatar
Default Re: ATTN: all drivers with 16" wheels!!! tire rubbing problem (xTravBx)
I never rub with my 16's and 2" Drop.
Old Mar 3, 2004 | 12:23 PM
BolivianDc2's Avatar
Default Re: ATTN: all drivers with 16" wheels!!! tire rubbing problem (MwGSR)
in order to see why you are rubbing your tires, u need to take the drop, the tire size, the rim size, and the offset all into consideration.
I have rims with +35mm, use 205/45-16 and it rubs like crazy on hard turns and sharp turns.
Getting a smaller profile tire will help eliminate teh problem, but you will also have a bigger gap between the fener and tire.
Old Mar 3, 2004 | 04:46 PM
ackerjack's Avatar
i never had this problem myself and im riding on 17s wrapped in the same 711 tires but i hda customer car with a problem simliliar if i understand correctly and all i did was order some spacers which solved the problem
Old Mar 8, 2004 | 04:31 AM
xTravBx's Avatar
Default Re: ATTN: all drivers with 16" wheels!!! tire rubbing problem (ackerjack)
How do you know if you're rubbing?
Old Mar 8, 2004 | 06:15 AM
AnotherGSR's Avatar
If you adjust or remove the camber kit from the rear it may stop the rubing in the rear.. If it rubs in front get a front camber kit and you should be good to go...
Old Mar 8, 2004 | 06:41 AM
Creep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xTravBx &raquo;</TD></TR><TR><TD CLASS="quote">How do you know if you're rubbing?</TD></TR></TABLE>
use your ears.
Old Mar 8, 2004 | 08:23 AM
iH8RICERZ's Avatar
no rubbing either w/ my 16's........
bringmyownend
Feb 16, 2009 04:37 PM
alex_s817
Apr 24, 2006 05:50 AM
mikeunreal
Suspension & Brakes
10
Mar 13, 2006 10:24 AM
swpdb16
17
Mar 27, 2004 11:00 AM
ebelp
Feb 6, 2003 09:05 AM
