Steering Wheel shakes when I brake???
Old Feb 19, 2004 | 01:09 PM
LOWLIFEHATCH's Avatar
Default Steering Wheel shakes when I brake???
I just got the Accord about a month ago its a 96 ex with cross drilled rotors in the front and stock in the rears. It has 45000 miles on it and when I hit the brakes the wheel starts to shake. Its not really bad but its annoying... Just wondering what it could be...The car was my dads and he changed the brake at 40000 miles.. Can the the rotors be warped already? Any help would be great thanks....
Old Feb 19, 2004 | 01:47 PM
CW96's Avatar
Default Re: Steering Wheel shakes when I brake??? (LOWLIFEHATCH)
this use to happen on my sisters car, the dash basically shaked when the car would be breaking, she even thought it was the steering wheel but it was just vibrating becasue of the dash. i say just have it checked out, shouldnt be that bad.
Old Feb 19, 2004 | 01:59 PM
88strippedhatch's Avatar
yeah cross drilled one time and heated them up good and the same problem started. Took them off and found that they were warped so you should probably check that first. You never know how they were treated before
Old Feb 19, 2004 | 02:01 PM
Default Re: Steering Wheel shakes when I brake??? (88strippedhatch)
the car was m dads and he babyed the car as you can see a 96 with 45000 miles on it. The wheel only shakes a little bit but its just annoying. Any quick fix with out changing the rotors?
Old Feb 19, 2004 | 03:39 PM
turbolshatch's Avatar
the rotors are proly warped.
Old Feb 19, 2004 | 07:02 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LOWLIFEHATCH &raquo;</TD></TR><TR><TD CLASS="quote">the car was m dads and he babyed the car as you can see a 96 with 45000 miles on it. The wheel only shakes a little bit but its just annoying. Any quick fix with out changing the rotors? </TD></TR></TABLE>
resurface the rotor would be the easy route and least expensive.
Old Feb 20, 2004 | 05:50 AM
pro1342's Avatar
Most likely the rotors are warped, but the tie-rod ends could be bad too.
Old Feb 20, 2004 | 06:15 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: (pro1342)
regardless if he baby'd the car or not, you can still warp your rotors. and not all machine shops are willing to even try and resurface a cross drilled rotor.
Old Feb 20, 2004 | 10:50 AM
95swappedsi's Avatar
as said sounds like rotors but ball joins could cause similar feeling
Old Feb 20, 2004 | 10:54 AM
Lscivichatch92's Avatar
Same thing happend to me your rotors are warped. Except Ignored mine and in 2 months i had to get new rotors, pads and calipers so i just went ahead and got integra brakes all round.
Old Feb 20, 2004 | 11:52 AM
Default Re: Steering Wheel shakes when I brake??? (Lscivichatch92)
Thanks ill see what happens
Old Feb 20, 2004 | 07:12 PM
Mohudsolo's Avatar
Happened all the time with my sister's car that she drove really easily. It was rust buildup on the inside and outside edges of the rotors. Light, easy braking did not flake it off. Chipping it off would cure it for about 6 months, then do it again. There is also a good chance the drilled rotors warped more easily than stock ones would. I would just replace them with stock autoparts store ones.
Old Feb 21, 2004 | 04:01 AM
Default Re: Steering Wheel shakes when I brake??? (Mohudsolo)
Im gonna go get them resurfaced this week and see what happens
Old Feb 21, 2004 | 09:23 AM
Also check your rack it might be loose that is a possibality
Old Feb 21, 2004 | 11:07 AM
Ok so now if I wanted to take my rotors off all i need to do is take off the brake caliper and then unsrew the rotors two bolts and thats it?
Ohbebe75
Oct 24, 2015 07:50 AM
TOO MUCH TORQUE
Aug 15, 2010 06:53 PM
skn181
Jul 1, 2007 06:45 AM
teletekman
May 3, 2006 09:15 AM
LOWLIFEHATCH
Feb 22, 2004 08:06 AM
