Oil leak?
Old Feb 19, 2004 | 12:34 PM
ProEater's Avatar
Default Transmission Fluid Leak?
*edit: im an idiot and titled the thread oil leak *
wasnt sure where to post this so im trying here. my friend's ford contour (just a car, not supposed to be cool ) has been leaking tranny fluid. i checked seals and everything and found the leak. it has a small crack, almost unvisible at the bottom of the trans case.
my question is, could this be spot welded? or would the whole trans case need to be replaced? thanks in advance!
Ian
Old Feb 19, 2004 | 04:22 PM
RCautoworks's Avatar
Default Re: Transmission Fluid Leak? (ProEater)
If you get someone that knows how to weld good then yes it can more then likely be welded , jb weld might actually work for the time being also.
Old Feb 19, 2004 | 07:00 PM
perlmeister8's Avatar
Default Re: Transmission Fluid Leak? (90blackcrx)
Yeah just drain all of the fluid, and JB weld will work quite well. Be sure to get the quick drying JB weld, if your bud wants to drive it the same day.
Old Feb 19, 2004 | 07:39 PM
mr.beeks's Avatar
Default Re: Transmission Fluid Leak? (perlmeistere81)
make sure you clean surface and scrape a little
so that jb weld would work...
Old Feb 19, 2004 | 08:06 PM
ProEater's Avatar
Default Re: Transmission Fluid Leak? (mr.beeks)
awesome, thanks for all the help. jb weld should work. not sure why i didnt think of it
Acidcrakker
Nov 30, 2007 02:58 AM
c1_sleeper
Sep 18, 2006 01:54 PM
janz3n
Mar 13, 2006 09:03 PM
kevinmac99
Oct 14, 2004 05:44 AM
obd2gsr
Apr 13, 2002 01:08 PM
