???'s about parts needs to instal coilovers
Old Feb 19, 2004 | 10:17 AM
90hatchie's Avatar
Default ???'s about parts needs to instal coilovers
hey i am about to get get some new coilovers and i was wondering what else i am gunna need to install so they will work. i drive a '90 dx hatch and it already has some shitty old coilovers on it. thanks alot for your help please respond asap.
Old Feb 19, 2004 | 10:27 AM
90hatchie's Avatar
Default Re: ???'s about parts needs to instal coilovers (newark man)
no new struts or anything?
Old Feb 19, 2004 | 10:33 AM
Outsane's Avatar
Default Re: ???'s about parts needs to instal coilovers (90hatchie)
are you getting true coil overs..or sleeves?
If your getting sleeves you can use your old shocks..unless they are blown or are not good enough for the new springs
Old Feb 19, 2004 | 10:40 AM
90hatchie's Avatar
Default Re: ???'s about parts needs to instal coilovers (Outsane)
im gettin coilovers. but when i asked a machanic i know, he said someshit about i had to get new struts for the new coilovers. and i would need a spring compressor to put them on. even though i already have coilovers on there.
Old Feb 19, 2004 | 12:01 PM
Outsane's Avatar
you don't need a spring comressor,
and you would only need new shocks if there is something wrong with yours..
Old Feb 19, 2004 | 12:08 PM
mamaboy's Avatar
you won't need anything else but a simple set of ratchet/sockets and a torque wrench. Check the spring rates.....if they are too stiff then your stocks will definately not last very long......therefore ride and safety will suffer
Old Feb 19, 2004 | 04:12 PM
Outsane's Avatar
are you running on stock struts now?
dctotheeg
Suspension & Brakes
Oct 18, 2005 11:37 AM
eh2..765
Suspension & Brakes
Jun 15, 2005 12:15 PM
matttegra
Sep 16, 2003 04:57 PM
HatchbackSiVtec
Mar 18, 2003 11:16 PM
