JDM YS1 Tranny Rebuild parts????
Old Feb 19, 2004 | 08:11 AM
MrCrx's Avatar
Default JDM YS1 Tranny Rebuild parts????
I heard that you can use hydro parts in this cable ys1 tranny. Is this true. Can I replace gears and syncros with usdm ITR parts? 3rd and 4th gear are kind of falling apart. Thanks in advance. Rob
Old Feb 19, 2004 | 09:39 AM
TECH43 RACING INC.'s Avatar
Default Re: JDM YS1 Tranny Rebuild parts???? (MrCrx)
yes. ys1 has hydro internals.
Old Feb 19, 2004 | 07:46 PM
smokey2.0's Avatar
Default Re: JDM YS1 Tranny Rebuild parts???? (TECH43 RACING INC.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. &raquo;</TD></TR><TR><TD CLASS="quote">yes. ys1 has hydro internals.</TD></TR></TABLE>
what he said
Old Feb 20, 2004 | 02:02 AM
Kwuaymaikrup's Avatar
Default Re: JDM YS1 Tranny Rebuild parts???? (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">
what he said </TD></TR></TABLE>
Isn't the JDM Ys1 a cable trans? If so, that won't work will it?
Old Feb 20, 2004 | 05:14 AM
MrCrx's Avatar
Thanks for the replys guys.
Old Feb 20, 2004 | 07:05 AM
Suprdave's Avatar
I thought yu could only rebuild USDM YS1 with Hydro parts?
Old Feb 20, 2004 | 09:46 AM
Default Re: JDM YS1 Tranny Rebuild parts???? (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">
Isn't the JDM Ys1 a cable trans? If so, that won't work will it?</TD></TR></TABLE>
ys1 transmissions, which are cable, (92-93 integra vtec & non vtec) do have HYDRO internals. heres a clue.....92-93 integras need big spline clutches, just like 94-up integra.
Old Feb 20, 2004 | 10:25 AM
Thanks for the clue...I wasn't sure what year trans he had since it wasn't said. Another thing about the splines though. I just recently put a clutch in my 94 GS-R and used the same clutch alignment tool I had used on my 90 B16 cable trans. How is that possible? I though the input shaft was supposed to be larger on the 92+ trans?
Old Feb 20, 2004 | 10:58 AM
lucky one's Avatar
I like all trannys like d-series ones how about you tech43?
Old Feb 20, 2004 | 01:21 PM
Default Re: JDM YS1 Tranny Rebuild parts???? (lucky one)
i love d series trannies..
i am building a zc supercharged with dual 850 cfm double pumpers and hks aic fueling 4 1200 cc injectors, and im using a ford mustang ecu for timing. im running a adaptor plate to use a accord auto trans with a 7000k rpm stall. three on the tree and four on the floor with a holley chromoly cam shifter. yee haw, get down boogie party!
Old Feb 20, 2004 | 01:23 PM
smokey2.0's Avatar
Default Re: JDM YS1 Tranny Rebuild parts???? (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">I thought yu could only rebuild USDM YS1 with Hydro parts?</TD></TR></TABLE>if that was true, i wouldn't have a rebuilt kit on top of my refrigerator(so the kids won't touch it) from my own experience, i can tell you that the hydro 3/4 synchro, shift forks, and selector rings, are much larger than the cable pieces!
Old Feb 21, 2004 | 02:00 AM
Mista Bone's Avatar
D Tranny Guru
Nobody loves the D tranny more than me, except maybe Jamie Houseman.
charjacq
Jul 28, 2004 09:07 PM
jDMJeRk
May 24, 2004 12:09 AM
9200RPM
Dec 11, 2003 05:50 AM
-Racer X-
Jul 23, 2003 08:22 PM
smokey2.0
Jun 9, 2003 07:44 PM
