BSQ - K&N air filter
Hey BSQ - I would like some more details on your 'Icebox' too. I have seen it on your website, but more info and pics would be helpful. Any details on the actual install would be good.
I am going to construct my own soon and get rid of my AEM.
Thanks!!
Thanks!!
yeah, i also have a question....... does the 3" PVC pipe that connects to the bottom of the stock airbox fit exactly with each other? cuz the bottom of the airbox has an oval shape while the PVC pipe has a circular opening
Are you still using the K&N Ru-2820 air filter?
Is it modified or is it a straight drop-in?
Can you supply details on modifications?
To see a photo of the modified RU-2820 go to http://www.geocities.com/bretq/kn2820_airfilter.html . You will also see a photo of the RU-2820, RU-3130 and the stock filter. You also notice that the end cap from the stock filter can be attached to the end of the RU-2820.
One thing that I forgot the mention in the instructions is that you will need to compress the end of the thin-walled PVC that will pass through the hole in the bottom of the airbox. By compressing the end of the PVC piping it will allow it to conform to the oval opening in the bottom of the airbox. Once the PVC has been compress on the sides and inserted into the opening it will conform properly to opening and will be sealed by the rubber gasket.
[Modified by BSQ, 5:48 PM 10/11/2001]
