Spoon Vs. Mugen head gasket Which is better for Turbo?
Old Feb 18, 2004 | 07:26 PM
eg360B's Avatar
Default Spoon Vs. Mugen head gasket Which is better for Turbo?
I have a b16. I am thinking of goin Turbo. The Spoon Sport 2 ply head gasket is measured at .45mm while Mugen is measured at .47mm. Which is better for Turbo set up? Or for Supercharger or r they the same? please help. let me know. thanks
Old Feb 18, 2004 | 07:32 PM
Padawan's Avatar
Darth ModerVader
Default Re: Spoon Vs. Mugen head gasket Which is better for Turbo? (DreK9)
I would imaging most people (myself included) are going to say "neither", since it is uncommon to see a thinner-than-stock gasket being used on a turbo application (for various reasons). If you're looking for an aftermarket gasket for FI, I'd suggest Cometic or Toda.
Civic Hx-T's Avatar
Greddy 2mm.
Old Feb 18, 2004 | 07:35 PM
NonovUrbizniz's Avatar
Loved
how much boost are you going to run... and is the HG bad now... or are you going to change it as part of the turboing process...
Frankly if you're not running high boost I'd just leave the head on there and not bother changing the HG...
How many miles on your engine now?
Old Feb 18, 2004 | 07:39 PM
AZSupraT's Avatar
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic Hx-T &raquo;</TD></TR><TR><TD CLASS="quote">Greddy 2mm. </TD></TR></TABLE>
.hugo's Avatar
Yeah as stated, neither is better. They both increase compression. When building a motor for boost, the goal is to lower compression.
Old Feb 18, 2004 | 07:41 PM
VinceVTEC's Avatar
Default Re: (Civic Hx-T)
I wouldn't use either of those headgaskets for turbo. Sure, high compression turbocharged cars make a lot of power, but to be on the safe side, people usually go with a lower compression. this gives more room for error, and not blowing your motor.
I hear good things about cometic headgaskets. get a thicker than stock one.
thenick's Avatar
Default Re: Spoon Vs. Mugen head gasket Which is better for Turbo? (starang)
stock 3 layer
JDM97dc2R
Mar 4, 2005 11:32 PM
bubbajim
Aug 21, 2003 07:26 PM
slamdunkcivic
Jul 23, 2003 12:37 PM
_BEN_
Jul 17, 2003 12:56 PM
snake01
Nov 13, 2002 03:26 PM
