Acura NSX Honda / Acura NSX 1990 - 2005 || Honda / Acura NSX 2017 -
lowering nsx
Old Feb 18, 2004 | 07:07 PM
yakitori's Avatar
Default lowering nsx
is it hard to do? what type of precations should i take ? is it the same as lowering a civic?
Old Feb 19, 2004 | 02:07 AM
preluda92's Avatar
Default Re: lowering nsx (yakitori)
The NSX uses a complicated web of springs, shocks, and rubber band like "absorption dampeners" All of which are pretty entangled in the exhuast bearing system... it's a very difficult process to remove all the safty pins and other precautions holding the whole system together. Not to mention the fact that it's a Solid rear axle car so your gonna need blocks, and bigger U-bolts. Good luck man.
Old Feb 19, 2004 | 06:04 AM
Ponyboy's Avatar
Painting Masterpieces
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yakitori &raquo;</TD></TR><TR><TD CLASS="quote">is it hard to do? what type of precations should i take ? is it the same as lowering a civic? </TD></TR></TABLE>
Just make sure you add housefold refuse to the flux capacitor and the rest is smooth sailing y0!
Seriously, how are you lowering it? Aftermarket springs...don't tell me your cutting the springs?
Old Feb 19, 2004 | 02:57 PM
yakitori's Avatar
Default Re: lowering nsx (Ponyboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ponyboy &raquo;</TD></TR><TR><TD CLASS="quote">
Seriously, how are you lowering it? Aftermarket springs...don't tell me your cutting the springs?</TD></TR></TABLE>
after market springs
Old Feb 19, 2004 | 04:18 PM
Ponyboy's Avatar
I didn't see a DIY on Danoland's web site or Prime but the search feature on Prime should be able to help you out. I know I've seen it there before. Basically, IIRC, the fronts are a fairly basic procedure but the rears are a bit more troublesome. I think you have to use a leverage bar to force some rear suspension peices out of place. How's that for ambiguous!?
Old Feb 20, 2004 | 05:39 AM
MiraiZ's Avatar
Is it just me or is the NSX forum getting as about as sarcastic as the Type R forum?
Old Feb 20, 2004 | 08:19 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ponyboy &raquo;</TD></TR><TR><TD CLASS="quote">I didn't see a DIY on Danoland's web site or Prime but the search feature on Prime should be able to help you out.</TD></TR></TABLE>
There is a section in the NSX FAQ and you can find it here:
http://www.nsxprime.com/FAQ/DIY/shocks.htm
However, it isn't in the index for the Do It Yourself area. (I just sent a note to the webmaster there to add it.)
Incidentally, I'm pretty sure the search feature on Prime doesn't work. (The search on the site which you would want for the FAQ. The search on the forums works.)
huge230
Nov 21, 2005 03:03 PM
huge230
Oct 5, 2005 09:54 PM
JerkzEm1
Suspension & Brakes
10
May 18, 2005 04:01 PM
Stunna BEN
Sep 29, 2004 03:28 AM
Jcook4130
May 8, 2003 12:27 PM
