anyone have type r cams in gsr?
Old Feb 18, 2004 | 02:57 PM
vietshinobi's Avatar
Default anyone have type r cams in gsr?
any one have type r cams in there integra? i have a stock gsr wondering if cams is worth the money? i run 1/4 mile 15.2. if i get the cams would i get into mid to high 14?
Old Feb 18, 2004 | 04:17 PM
kobe 8's Avatar
Default Re: anyone have type r cams in gsr? (vietshinobi)
i had the 98 itr cams when my gsr was n/a (i/h/e)...it nett'd 9whp (straight swap).
you'll def hit hi 14's....
Old Feb 18, 2004 | 04:24 PM
sa21199's Avatar
Default Re: anyone have type r cams in gsr? (kobe 8)
I had them but couldn't feel a big difference till I got the basic I/H/E. Once I had all that there was a huge difference
Old Feb 18, 2004 | 05:50 PM
skunkintegra's Avatar
Default Re: anyone have type r cams in gsr? (sa21199)
if you can get some for 2-300 bux.. then do it..
otherwise-- hold out for some TODA's/JUN's/Skunk2's/etc...
here's my gains from ITR header and cams in my GS-R
Old Feb 18, 2004 | 05:53 PM
PhReSh N KleAn's Avatar
I have 00 CDM ITR cams in my gsr with i/h/e/c, and it did add some noticeable torque up top and a nice sound, but it needs to be tuned to be a more worthwhile upgrade. my VTEC should be at like 5500 or around there as opposed to 4400
Old Feb 18, 2004 | 06:32 PM
b18cu's Avatar
Default Re: anyone have type r cams in gsr? (PhReSh N KleAn)
I ran 15.1, put on the skunk 2 IM and 98 itr cams and hit 14.7.
Old Feb 18, 2004 | 07:49 PM
revhigh89's Avatar
Old Feb 19, 2004 | 08:58 AM
Y2K Si FBP's Avatar
Default Re: anyone have type r cams in gsr? (evilryu530)
they worked awesome in my gsr motor. midrange power is great
i am selling them btw :D
https://honda-tech.com/zerothread?id=751130
325 shipped 00 type r same as CTR spec
Old Feb 19, 2004 | 11:45 AM
2fknlo's Avatar
Default Re: anyone have type r cams in gsr? (Y2K Si FBP)
You definitely feel more in the mid to high rpms
I didn't gain much on the strip going from 15.4 to 15.1.
Thats with all the I/H/E and suspension.
I need more practice...hehe
Old Feb 19, 2004 | 12:09 PM
turbotommy's Avatar
Default Re: anyone have type r cams in gsr? (2fknlo)
got em in a 98' gsr w/ typer pistons. SICK cams with an aftermarket ecu. with the stock gsr ecu there doo doo
Old Feb 19, 2004 | 12:28 PM
DSR!'s Avatar
Default Re: anyone have type r cams in gsr? (turbotommy)
If you wanna get cams that'll actually help with out having to replace everything in the engine, go with CTR cams. ITR cams are good, but not as good as these. They produce a lot of mid range power.
Old Feb 19, 2004 | 12:35 PM
dustrag's Avatar
so they integra type r cams go right in a gsr head w/ no valvetrain swaping... i thought you had to use the itr exhaust springs and retainers for that
Old Feb 19, 2004 | 12:37 PM
xx dc2teg xx's Avatar
Default Re: anyone have type r cams in gsr? (DSR!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSR! &raquo;</TD></TR><TR><TD CLASS="quote">If you wanna get cams that'll actually help with out having to replace everything in the engine, go with CTR cams. ITR cams are good, but not as good as these. They produce a lot of mid range power. </TD></TR></TABLE>
ctr cams and ite 00-01 are identical...
theres a lot of info if you search about valvetrain upgrades when swapping in cams.
Old Feb 19, 2004 | 12:58 PM
dustrag's Avatar
i am asking this b/c they are saying here that it is a direct swap!~
Old Feb 19, 2004 | 01:25 PM
sinfulDB1's Avatar
Default Re: (dustrag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustrag &raquo;</TD></TR><TR><TD CLASS="quote">so they integra type r cams go right in a gsr head w/ no valvetrain swaping... i thought you had to use the itr exhaust springs and retainers for that</TD></TR></TABLE>
you need the valve springs and retainers if you plan on raising the rev limiter.. if you are going to keep the stock redline you wont need the rest of the ITR valvetrain
Old Feb 19, 2004 | 02:39 PM
Ti3d in's Avatar
00-01 ITR cams and CTR cams are the exact same thing, except some shops charge more for CTR cams because its JDM. The older ITR cams have 3 less degrees of duration. It's not really a big deal, but there is a price difference.
dandim23
Aug 27, 2013 06:57 PM
GSRintegra_Bob
Oct 19, 2005 03:11 AM
GoodFella
Feb 18, 2004 12:58 PM
