Car Won't start...
Old Feb 18, 2004 | 01:55 PM
Duster's Avatar
Default Car Won't start...
Hey guys just a quick question to see what you guys think
my car is carb'd , no fuel injection, and it won't start....it turns over so i know thats working. friend suggested might be ignition coil?? but that wouldn't just stop working one day it would be gradual wouldn't it?? I've tried pouring fuel right into the carb cause i know thats worked on my buddys car. Any suggestions?? maybe theres condensation in the fuel line?? if so how would i get that out?? thanks
Modified by Mazdillac at 11:48 PM 2/18/2004
Old Feb 18, 2004 | 03:34 PM
Chiovnidca's Avatar
Default Re: Car Won't start... (Mazdillac)
Does it have spark?
Old Feb 18, 2004 | 03:37 PM
Duster's Avatar
Default Re: Car Won't start... (Chiovnidca)
As far as i know it does....i did the spark plugs not even 2 months ago...all the plugs cables are connected and everything....any ideas?
Old Feb 18, 2004 | 06:30 PM
bayarea13's Avatar
check for spark out of the coil. you most likely will not have spark. if you dont have spark check for power and ground to the coil. the ground should be pulsing on and off, collapsing and building a magnetic field inside the coil. if it has power and a pulsing ground, but no spark replace the coil. if not check for CKP signal, or do a scratch test to simulate CKP signal. to scratch test, touch ground to the white wire in the distributor. (not 100% sure white but almost). if you spark test it and it sparks you know you need a new CKP sensor, replace distributor. if you have CKP and SYNC signal to PCM, check PCM signal to ignitor. if no signal present, check power and ground to PCM. if PCM has power, ground, signal in and no signal out replace PCM. if it is missing any of those find out why. if PCM is sending a digital signal to the ignitor, and the ignitor has power and ground but is not pulsing the ground to the coil, replace the ignitor. ignitors are the most common, highest failure part. if you have spark, check to make sure you have fuel, but it will most likely have fuel being carburated unless the fuel pump is bad. so if you have spark and fuel, but it wont start, check compression and timing belt. if you have compression, proper valve timing, spark, and fuel you are most likely missing something. possible plugged exhaust. good luck.
Old Feb 19, 2004 | 10:13 AM
Duster's Avatar
Default Re: (bayarea13)
Hey man: I got the car running, thanks alot for your detailed explaination..
Old Feb 19, 2004 | 09:08 PM
bayarea13's Avatar
what was wrong with it?
Old Feb 19, 2004 | 10:58 PM
Duster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bayarea13 &raquo;</TD></TR><TR><TD CLASS="quote">what was wrong with it?</TD></TR></TABLE>
I'm not exactly sure, i went out there the next morning, pushed it into the carport, popped the hood, disconnected and reconnected everything i could that you mentioned, distributor, the distributor caps, the ignition, the plugs and checked em and the plug wires, everything appeared to be fine and so i tried to start it and it fired right up, so i am not exaclty sure what was wrong but it was something in there, is run perfect sence...
hey man
Dec 22, 2010 06:59 AM
mini-meEj1
16
Jan 1, 2008 10:14 AM
Cpt Ben
Oct 14, 2006 12:34 PM
SwiftTypeR
Oct 20, 2004 07:49 PM
BadBeck
Dec 11, 2003 05:59 PM
