Big bore throttle bodies $100.
No Big Whoop
http://www.Maxbore.com
for all your trottle body boring needs.
I have been on honda-tech for a long time, but it is no longer the honda-tech we all knew. It is now owned by corporate america and no longer friendly to the small enthusiast based business this place once was.
Thank you honda-tech members for your support.
Modified by Maxbore.com at 6:16 PM 2/5/2008
No Big Whoop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vandilist »</TD></TR><TR><TD CLASS="quote">i need people to vouch for you and your work</TD></TR></TABLE>
Stick around because I have done quite a few for H-T members.
I take pride in my work and it reflects on the quality of the the throttle bodies I bore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20eg »</TD></TR><TR><TD CLASS="quote">I will be sending you a gsr tb soon...66 is the biggest you can go. Is that right??
bump it up</TD></TR></TABLE>
No, 65mm is the biggest for a type R throttle body.
A GSR throttle body goes to 64mm.
Modified by The new Spaceballs at 10:48 PM 10/30/2004
No Big Whoop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">Whats the biggest you can bore out a b16 Tb?
I think stock is what.. 60mm. So to 64mm?
-Eric</TD></TR></TABLE>
It depends. if it is a first gen JDM B16, the biggest is 62mm.
If it is a USDM B16 , then 64mm.
Thanks.
Thanks.
I can vouch for George, He did a few TB's for me and they came out great. Great service and quality work.
Here are some pics of a GSR TB he bored for me.
No Big Whoop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12secB18acivic »</TD></TR><TR><TD CLASS="quote">Can u provide the throttle body? If so, how much would it be?</TD></TR></TABLE>
No, sorry.
I do not provide throttle bodies, I offer a service only.
Thanks.
No, sorry.
Thanks.
No Big Whoop
Yes, I HAVE to make a new butterfly.
Otherwise you would have 2mm gap all around it, and the idle would be at around 3000RPM.
Both GSR and 2000 Civic Si can be bored to 64mm at the butterfly.
Thanks
Thanks
Bump for a great guy!
I just had a question.
I have a GSR TB and a Skunk2 IM.
I'll be using a ITR throttle cable and bracket. I would also need to MODIFY the spring/wheel on the TB to another NON-gsr spring/wheel. Are you able to do that?
What i mean by the spring/wheel is the part that the throttle cable rides on to open/shut the throttle body plate.
It's a common mod to the GSR TB when most guys go with the Skunk2 IM cause the want the cleaner look.
No Big Whoop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">Bump for a great guy!
Are you able to do that? </TD></TR></TABLE>
Yes. I can do that.
Throw in $20 and I will convert it to work like the type R throttle body.
Thanks!
Modified by The new Spaceballs at 12:23 PM 4/13/2004
Yes. I can do that.
Thanks!
