h&r cup kit for ep3?
has anybody heard anything about the h&r cup kit for ep3's? http://www.tirerack.com has them but i didnt see anything about it on h&r's website. any info would be helpful as it seems to be a fair price for a shock/spring combo!
-Daniel
btw here is the link to the page where tire rack has the cup kit for the ep3's...
http://www.tirerack.com/suspen...n+Kit
-Daniel
You might give these guys a call....
http://www.gmpperformance.com/...s.htm
Steven has a lot of experience with the H&R products...
According to H&R, they are "still in development." That was a couple weeks ago when I called, but he had no concrete information about thier release.
for the ep3, depending on the size of your front lower strut bolts, you can use either the civic coupe cup kit, or the rsx cup kit.
14mm front strut bolts = civic coupe
16mm front strut bolts = rsx
H&r will probably produce some revised spring rates specific to the ep3, so it wouldn't hurt to wait. but if you need to drop now, you can get one of the other cup kits.
Hopefully h&r will produce two different versions to work with the 14mm & 16mm front strut bolts. either that, or sell only the kit with the 16mm holes and force the 14mm folks to "upgrade". :D
