suspension question...can u guys help me out please??
whats up guys...i havent posted in a long time so i had to make a new user name...anyways....my question is if i could put the front hubs from a 94+ integ on to my rex...please let me know as much as you can because i plan on doing so as soon as soon as possible. and i know the ones from a 90+ integ will fit but i allready have the parts and i want bigger brakes....if it helps i have a 89si....any help would be much appreciated....
Modified by Bruce_Leroy_ at 9:27 AM 2/20/2004
Upper or lower? I wouldn't change either of them, I have Teg brakes up front and I kept both my upper and lower stock arms....
i think they will fit but they will be longer, so if your car is lowered you might have a problem with the upper control arm hitting the top of the unibody... it will probably throw your alignment out as well... if you want integra front brakes find some 90-91 civic ex knuckles and use the front brakes from a 90-93 teg... they will all bolt up and the ex knuckles are the correct size
blaze_125
May 1, 2009 11:26 AM
buck02
Dec 18, 2003 08:46 AM
ThatRicerDaniel
Apr 8, 2003 03:17 PM
TegRun
Mar 14, 2003 01:20 PM
