Should I buy used rc injectors?
Old Oct 10, 2001 | 10:59 PM
Trajic's Avatar
New User
Default Should I buy used rc injectors?
My friend is seling me his rc 550cc injectors for $100. They were recently flowed and balanced. I wanted to know if i should buy them or is ther a risk they mite fail or not work well or something
Old Oct 10, 2001 | 11:14 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Should I buy used rc injectors? (Trajic)
Correct me if I'm wrong but I think that RC cleans and flowtests them for free....
If your worried about them being clogged up
Old Oct 10, 2001 | 11:42 PM
Trajic's Avatar
New User
so should i buy them
Old Oct 11, 2001 | 04:50 AM
Ubermensch's Avatar
Old Oct 11, 2001 | 07:07 AM
VTC_CiViC's Avatar
Default Re: Should I buy used rc injectors? (Ubermensch)
Well if you don't.. I want them!!
Old Oct 11, 2001 | 07:17 AM
WykidEH's Avatar
Default Re: Should I buy used rc injectors? (VTC_CiViC)
GET THEM!
Old Oct 11, 2001 | 10:07 AM
rtype11's Avatar
No you should not use them at all, they are very very very bad, what you should do is give me your friends phone number so I can call him and tell him not to sell them to you because the are so bad.
I may just have buy them from him to take them off the market so that they do not cause any harm to you my friend!
Old Oct 11, 2001 | 10:13 AM
DamonBoost's Avatar
New User
Default Re: Should I buy used rc injectors? (rtype11)
yeah u should buy them and sell them to me for $150..then you will be making money.. see isnt that a good idea
Old Oct 11, 2001 | 10:24 AM
rtype11's Avatar
Default Re: Should I buy used rc injectors? (ill logic)
no you should sell them to me for $151 because I am in a wheelchair and live in a bubble.
Ill logic is a millionaire and doesnt need injectors, his car runs on Mr. Fussion, and he lives his life one 1/4 mile at a time, for those 10 seconds or less he doesnt need your injectors.
Old Oct 11, 2001 | 10:34 AM
DamonBoost's Avatar
New User
LMFAO
Old Oct 11, 2001 | 12:41 PM
5 Liter Eater's Avatar
Default Re: Should I buy used rc injectors? (newgsr)
Can anyone verify this?
Thanks,
[Modified by 5 Liter Eater, 3:41 PM 10/11/2001]
Old Oct 11, 2001 | 01:17 PM
TurboT's Avatar
Default Re: Should I buy used rc injectors? (5 Liter Eater)
YES, RC does clean and balance for free
just as long as they are RC injectors
Old Oct 11, 2001 | 01:24 PM
dustin's Avatar
Default Re: Should I buy used rc injectors? (TurboT)
Hmm I should send the 550cc RCs in that I just bought then.
Old Oct 11, 2001 | 01:39 PM
Suprdave's Avatar
Default Re: Should I buy used rc injectors? (dustin)
If those are the same $100 DOllar injectors on DSM Trader...those are Peak\Holds and you cant just plug them into a Honda. Need Resistor Packs...
Suprdave
Old Oct 11, 2001 | 03:58 PM
Turbo00's Avatar
New User
Default Re: Should I buy used rc injectors? (Suprdave)
i thought the DSM injectors fit in honda's they just had to be OBD1 injector clips?
Old Oct 11, 2001 | 08:24 PM
VTC_CiViC's Avatar
Default Re: Should I buy used rc injectors? (Turbo00)
If i'm not mistaken, OBD-I Honda's use peak/hold injectors, OBD-II use saturated.. correct?
Old Oct 11, 2001 | 08:38 PM
dustin's Avatar
Nope, it depends on the year of the car. 94+ civics and integras use saturated. G2 integras use peak&hold. Preludes use peak&hold up until 95 or so I believe.
Dustin
Old Oct 11, 2001 | 08:43 PM
DamonBoost's Avatar
New User
so dustin would i need the clips or not? 94 integra LS?? also would dsm injectors fit in my car or would i need some modification to make them fit?
Old Oct 11, 2001 | 09:08 PM
The Punisher's Avatar
I just got my 750 cc DSM injectors in the mail the other day. I am still waiting on my fuel rail and FPR to show up. I will tell you if they are a direct fit or require modification. If I am not mistaken, you would need a resister pack for the p & h DSm injectors. I have found a site that sells them pretty cheap. I only paid $499 for my 750 cc. www.dsm-performance.com Here they are. But I would watch Ben @ importparts, he just reduced his 550's to $295, and the resister packs to $40. That is awesome!
Old Oct 16, 2001 | 10:01 AM
Default Re: Should I buy used rc injectors? (gsr*lude)
G3 Integras use saturated. The way to check is to Ohm the terminals on the injectors. If it is more than 17 Ohms they are Peak Hold and will require resistor packs on a car that uses saturated injectors.
2ndchirp
May 24, 2009 07:16 AM
HaiSpeedRacer
Aug 16, 2007 01:13 PM
mugenintegra16
May 16, 2003 07:28 PM
