?? on Poor Man R build up
Old Feb 18, 2004 | 01:27 AM
JDMjdawg's Avatar
Default ?? on Poor Man R build up
I posted this in the all motor forum already....I never seem to have much feedback there though, so here goes in the Hybrid section...
I currently have a 96' EK4 motor...
I'm going to be putting together a GSR block and need to know a couple things. I really need to know what would be a good piston to run. USDM or JDM ITR? CTR? B16a USDM or JDM? If anyone knows what compression I'd yield with these please let me know. I've heard alot about different comp. ratios but nothing solid. The C-speed comp. calculator seems a bit off, or I'm just not using it right On the B16 head I have ITR valvesprings, Crower titanium retainers, ITR cams, ITR intake mani., ported tb, b&m fpr, skunk cam gears. I'm going to be running a CTR intake cam on the new setup though. I also plan to get Hondata S100. I think my exhaust shouldnt hold me back too much....I have a Fujitsubo 4-2-1 header, 2.25 mandrel bent piping, and a Mugen twin loop.
Any ideas of HP and TQ #'s???
Yes...in advance, I did search. Found alot of Poor Mans R ****, but nothing that helped too much. Thanks guys.
Old Feb 18, 2004 | 03:11 AM
JDMjdawg's Avatar
Default Re: ?? on Poor Man R build up (JDMjdawg)
up
Old Feb 18, 2004 | 06:19 AM
spunky424's Avatar
currently im runing a poor man's itr(b18c block with b16 head)...i'm running usdm type r pistons for a compression of about 10.8...also have a built head with skunk2 stage 2 cams/valves/valvesprings/ and retainers...have no regrets....before i dropped in the cams i was pushing 175whp not bad if i say so myself...i wonder wut i'm putting down with the new headwork
Old Feb 18, 2004 | 11:14 AM
JDMjdawg's Avatar
Default Re: ?? on Poor Man R build up (spunky424)
damn...that sounds pretty good. So USDM ITR pistons give you 10.8:1?
Old Feb 18, 2004 | 09:29 PM
JDMjdawg's Avatar
up up and away!
Old Feb 19, 2004 | 10:35 AM
JDMjdawg's Avatar
Old Feb 19, 2004 | 04:30 PM
Wes d's Avatar
If you are building I'd definitly go with the jdm itr pistons. They are a few points higher than the US ones, and have the trick moly coating on them.
Old Feb 19, 2004 | 08:14 PM
JDMjdawg's Avatar
Default Re: ?? on Poor Man R build up (Wes d)
Yeah....I think I'm going with the JDM ITR's.....compression calculator says 11.5 from c-speed. I didnt think it would be that high. I hear it would be more like 11.2 or so.
Old Feb 20, 2004 | 12:21 AM
Trey's Avatar
25 Year Member
USDM 99-00 Si pistons are the same compression ratio as the JDM ITR pistons and a lil cheaper. I have them in the motor I rebuilt.
Old Feb 20, 2004 | 09:09 AM
civicsib16b's Avatar
Default Re: ?? on Poor Man R build up (Trey)
if it was me i would run ctr piston!
Old Feb 20, 2004 | 02:48 PM
thad
Guest
Posts: n/a
Default Re: ?? on Poor Man R build up (civicsib16b)
i'm running ctr's in mine.
Old Feb 20, 2004 | 04:10 PM
JDMjdawg's Avatar
Default Re: ?? on Poor Man R build up (thad)
CTR's...Hmm. What compression are you at? What kind of cams do you run?
JDM_EK_JOE
Mar 6, 2009 08:01 PM
1stealthls
44
Jan 26, 2005 09:02 PM
JDMjdawg
23
Feb 21, 2004 06:40 PM
AztecB17
Apr 3, 2002 09:49 PM
Stunna BEN
Nov 9, 2001 11:00 AM
