No cruise control with hondata
Old Feb 17, 2004 | 09:21 PM
2000GSRT's Avatar
Default No cruise control with hondata
When I had my hondata installed I lost my cruise control feature. Anybody know a way that I can get it to work again?
I've searched, but haven't found anything specific.
Thanks
Old Feb 18, 2004 | 08:30 AM
Spunkster's Avatar
Default Re: No cruise control with hondata (2000GSRT)
Probably your clutch switch. The ecu has nothing to do with cruise control.
Old Feb 18, 2004 | 08:50 AM
canuck-mx6's Avatar
Default Re: No cruise control with hondata (Spunkster)
Mine still worked with hondata, it has nothing to do with Hondata
Old Feb 18, 2004 | 11:55 AM
2000GSRT's Avatar
Default Re: No cruise control with hondata (canuck-mx6)
Well it has something to do with wiring the launch limiter or full throttle shift to the clutch switch. Apparently the way in which he wired it up, caused my cruise control not to set.
Any ideas on what the problem might be?
Old Feb 18, 2004 | 12:13 PM
greebler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 &raquo;</TD></TR><TR><TD CLASS="quote">Mine still worked with hondata, it has nothing to do with Hondata</TD></TR></TABLE>
Yep
Old Feb 18, 2004 | 12:28 PM
2000GSRT's Avatar
Default Re: No cruise control with hondata (greebler)
stop being post ******, I know it's supposed to work with hondata, but mine doesn't. Obviously something was wired wrong. Any body want to tell me something I don't already know...
Old Feb 18, 2004 | 03:41 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000GSRT &raquo;</TD></TR><TR><TD CLASS="quote">stop being post ******, I know it's supposed to work with hondata, but mine doesn't. Obviously something was wired wrong. Any body want to tell me something I don't already know...</TD></TR></TABLE>
How is it wired up? Is it using the switch suplied by Hondata, or the original? Are the wires spliced, or is the rev limit harnes only plugged in?
Old Feb 19, 2004 | 08:31 AM
2000GSRT's Avatar
Default Re: No cruise control with hondata (Chiovnidca)
You know, I'm not really sure, I just took a look up there but it's so cramped and there are so many other wires in the way that I can hardly see anything.
I did find the clutch swith however and noticed that there was a white/clear plastic bracket with a pink and a black wire coming out of it, but nothing hooked up to the bracket.
I'm guessing this bracket may have been hooked up to the clutch swith and was pulled out to plug in the hondata bracket and that is why my cruise control is not working.
Old Feb 19, 2004 | 08:45 AM
JBBNJ609's Avatar
why dont you talk to the place who did the work , that would be the best answer i can give
Old Feb 19, 2004 | 01:55 PM
Chiovnidca's Avatar
Those would be for the clutch switch, so you have your answer.
Old Feb 19, 2004 | 04:53 PM
BoOsted-Hatch's Avatar
Well if you have a launch control,they most likely eliminated your cruise contorl. There is two switches on the clutch pedal area and hondata says replace the cruise contorl switch with the lauch contorl switch. You also can ask Hondata they most likely say the same.http://WWW.HONDATA.COM
Old Feb 20, 2004 | 07:36 AM
2000GSRT's Avatar
Default Re: No cruise control with hondata (Performance Hatch_BoOsted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Performance Hatch_BoOsted &raquo;</TD></TR><TR><TD CLASS="quote">Well if you have a launch control,they most likely eliminated your cruise contorl. There is two switches on the clutch pedal area and hondata says replace the cruise contorl switch with the lauch contorl switch. You also can ask Hondata they most likely say the same.http://WWW.HONDATA.COM</TD></TR></TABLE>
yeah, I think that's what happened. He replaced the cruise control switch, with the launch control switch.
So what do I do to get my cruise to work again? I read a post where somebody said to short 2 wires together.
https://honda-tech.com/zerothread?id=433596
Old Feb 25, 2004 | 09:29 AM
2000GSRT's Avatar
Just to let every one know I got it to work again.
I just shorted the pink and the black wire together. WOrks like a charm. Thanks for the replies
Old Feb 25, 2004 | 01:39 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000GSRT &raquo;</TD></TR><TR><TD CLASS="quote">Just to let every one know I got it to work again.
I just shorted the pink and the black wire together. WOrks like a charm. Thanks for the replies </TD></TR></TABLE>
You just have to remember hitting the clutch wont turn of the cruise now.
Old Feb 25, 2004 | 03:21 PM
2000GSRT's Avatar
yeah I know, but I never used to use the clutch anyway. thanks tho
sackdz
Aug 4, 2018 09:41 AM
quicknadc2
Mar 1, 2007 01:04 PM
Nextelbuddy
Apr 17, 2004 07:53 AM
