Honda S2000 Honda S2000
will a rsx tranny bolt up to a s2000 motor
Old Feb 17, 2004 | 09:00 PM
MUGEN982*'s Avatar
Default will a rsx tranny bolt up to a s2000 motor
Old Feb 17, 2004 | 09:26 PM
2+2=5's Avatar
Default Re: will a rsx tranny bolt up to a s2000 motor (MUGEN982*)
FWD RWD=NO
Old Feb 17, 2004 | 09:27 PM
DongTran's Avatar
Default Re: will a rsx tranny bolt up to a s2000 motor (2+2=5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2+2=5 &raquo;</TD></TR><TR><TD CLASS="quote">FWD RWD=NO</TD></TR></TABLE>
(2+2=5) = NO
sorry, just had to :D
Old Feb 17, 2004 | 10:20 PM
arcticblursx's Avatar
why would you want a RSX tranny anyways?
Old Feb 17, 2004 | 11:29 PM
evil vapor's Avatar
Default Re: (arcticblursx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arcticblursx &raquo;</TD></TR><TR><TD CLASS="quote">why would you want a RSX tranny anyways?</TD></TR></TABLE>
I'm guessing it's for a swap of some sort.
Old Feb 18, 2004 | 11:52 PM
Boost Ambassador's Avatar
Point exactly....
Old Feb 19, 2004 | 05:18 AM
H22A EG6's Avatar
Default Re: (LS60-1)
why would hooking a FWD tranny to a RWD motor cause a problem?
the K20 tranny is not compatible with the F20 motor that is why i wont work
Old Feb 19, 2004 | 11:03 AM
1bad-eg's Avatar
Default Re: (H22A EG6)
Are the bolt patterns the same or different on both the k and f blocks? If the same, there shouldn't be a problem. Unless of course the engine's turn differently. Then, that'll definitely be one quick setup.....in reverse
Old Feb 19, 2004 | 11:58 AM
cmdr430's Avatar
Default Re: (1bad-eg)
i believe the answer to you question may be YES!
https://honda-tech.com/zerothread?id=314294
check out p1auto.com
jack was the first to install a type r swap w/ immobilizer into a 92-95 hatch AND
do a k24 frankenstein into new si hatch
Old Feb 20, 2004 | 08:44 PM
conesmasher's Avatar
Default Re: (cmdr430)
Haha, I saw this awhile back and find it funny no one has responded to getting bitch slapped
Old Feb 22, 2004 | 08:49 AM
Buitrex's Avatar
I was going to say yes, but you already got the answer. Check out the link
http://www.prototyperacing.com
importtuner07
12
Jun 20, 2006 12:30 PM
Wazup
Dec 13, 2004 09:10 AM
sodacan33
Oct 30, 2004 05:27 AM
MUGEN982*
34
Feb 23, 2004 11:15 AM
salbaje
Sep 6, 2002 09:48 AM
