Lots of carbon build up on my rear end, whats causing it?
Old Feb 17, 2004 | 07:48 PM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Lots of carbon build up on my rear end, whats causing it?
I got lots of carbon build up on the outside of my muffler tip, and on my rear bumper as well, in fact i gotta wash my car every week. When I warm up my car in the morning, there is always some condensation that comes flying out of my muffler, and its usually black due to all the carbon inside the tip as well. On the floor in my garage there is like a black spot of carbon right where my tip is. I used to have a FPR but got rid of it since i didnt need it a while ago. My theory is that my O2 sensor is bad maybe? I'm most likely running rich. Or it may be my ignition systemnot burning the fuel efficiently cuz i got those cheap 9.3 mm plug wires? My distributor cap and rotor may need replacing? If anyone else has had this problem, let me know how u fixed it. thanks
Old Feb 17, 2004 | 07:52 PM
Ricey McRicerton's Avatar
Default Re: Lots of carbon build up on my rear end, whats causing it? (rukawa1one)
Either burning oil, running rich or you dont have a cat.
Old Feb 17, 2004 | 07:53 PM
UNCVLZD's Avatar
Do you use a cat? Maybe it's clogged. Does your exhaust smell like rotten eggs?
Old Feb 17, 2004 | 08:46 PM
95cxhatch's Avatar
Default Re: (mattoien)
i would say your burning oil and the burnt oils' residue (black carbon ash) is sitting in your pipes and gets blown out when you get on the gas....thats what mine was doing anyway, but i could also see a little bit a blue smoke when at WOT!
i changed my pipes and the insides were totally coated black!
Old Feb 18, 2004 | 10:37 AM
hondaaaaah's Avatar
Hey rukawa
I was wondering if you ever happened to find out what was causing all that carbon build up. I noticed the same thing on my '91HB a short while after installing an intake. I was told it was because I was running too rich as well but haven't really done anything about it. Any advice would be cool.
Old Feb 18, 2004 | 10:42 AM
Electron Si's Avatar
Default Re: Lots of carbon build up on my rear end, whats causing it? (hondaaaaah)
Yeah, truthfully, it sounds like you're running rich, but there is a good possibility that you are burning oil though. Have someone rev your car, and put your had behind the tail pipe when they rev, then smell your had, you can tell if it is gasoline, and if it is running rich but the sweet kind of smell, and plus the tip of your muffler will look fuzzy. Hope this helps.
Old Feb 18, 2004 | 10:50 AM
JdM DiNg DoNg's Avatar
Default Re: (95cxhatch)
whats WOT mean?
Old Feb 18, 2004 | 10:55 AM
Ya@inlinePRO's Avatar
Default Re: (JdM DiNg DoNg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DiNg DoNg &raquo;</TD></TR><TR><TD CLASS="quote">whats WOT mean?</TD></TR></TABLE>
wide open throttle
Old Feb 18, 2004 | 11:02 AM
Default Re: (kwik2nec)
ooooo..ight thanx... i got that carbon problem too..but i think its cuzz im not running a cat in my dx...
Old Feb 18, 2004 | 12:27 PM
hondaaaaah's Avatar
Default Re: Lots of carbon build up on my rear end, whats causing it? (Electron Si)
I'll give that a try too. I suppose that carbon will stain the chrome tip permanently?
Thanks
Old Feb 18, 2004 | 12:30 PM
hayabusa160's Avatar
i got the same problem lately its rather annoying. my friends say the exhaust smells pretty bad. i assume im running rich.
Old Feb 18, 2004 | 12:35 PM
-Justin-'s Avatar
i got the same problem. The only thing i have on my car is Skunk2 exhaust. I checked the distributor cap and rotor button, checked plug wires, checked plugs, checked pcv valve, and checked the timing. If it is burning oil or running rich how would you solve this?
Old Feb 18, 2004 | 12:37 PM
Marauder's Avatar
Default Re: (B16EH2)
Black dust on the back of the car is just normal. I get a LOT more now that I'm turbo. My friend has the same setup as me, but no cat, and he gets a whole lot more! Honda's just run rich toward the upper rpm's. Just normal.
Old Feb 18, 2004 | 01:39 PM
Default Re: (Marauder)
yea maybe thats it my friends tell me when i shift at high rpm a puff of black smoke comes out.
Old Feb 18, 2004 | 01:46 PM
SolObsession's Avatar
Default Re: (hayabusa160)
Same problem here....atleast my car is black and not white cuz then I'd have to wash the bumper instead of wiping the tip.
Old Feb 18, 2004 | 02:17 PM
-Justin-'s Avatar
yeah, my car is white. i imagine that is why it's so obvious.
Marauder you said you have dust on the back of your car but on the back of mine it seems like oil or something, if i rub it, it smears? u got the same crap on the back of your hatch?
Old Feb 18, 2004 | 02:25 PM
EGinNY's Avatar
I think every Honda i know has the same problem, some worse then others but they all pretty much smoke.......
One of the factors to owning a high-reving motor
oh and dont know if you hav a coupe or a hatch, but the hatch is the worst cause it gets caught up under the spoiler and ends up on your rear window
Old Feb 18, 2004 | 02:29 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95cxhatch &raquo;</TD></TR><TR><TD CLASS="quote">i would say your burning oil and the burnt oils' residue (black carbon ash) is sitting in your pipes and gets blown out when you get on the gas....thats what mine was doing anyway, but i could also see a little bit a blue smoke when at WOT!
i changed my pipes and the insides were totally coated black!</TD></TR></TABLE>
I would say that you haven't worked on very many cars yourself have ya?
Carbon builup is from fuel not oil.
Old Feb 18, 2004 | 02:34 PM
toadolson's Avatar
Can happen if you do only an exhaust and no intake. Or the other way around, intake and no exhaust.
Intake and no exahust, your takeing in more air than can be pumped out due to OEM exhaust.
Exhaust and no intake, computer overtakes and runs more fuel than needed. Think you get the general idea.
Old Feb 18, 2004 | 02:36 PM
Caveman74's Avatar
Default Re: (JDM-97CX)
When i got my Magnaflow I noticed the carbon on the bumper. Its normal. You just don't see it from the factory pipes, because of the small tip.
Old Feb 18, 2004 | 02:38 PM
cxjon's Avatar
Default Re: Lots of carbon build up on my rear end, whats causing it? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Either burning oil, running rich or you dont have a cat. </TD></TR></TABLE> that three is all my problems :D
Old Feb 18, 2004 | 03:23 PM
95cxhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">
Carbon builup is from fuel not oil. </TD></TR></TABLE>
your 17 years old man!.....i've been driving a honda for years b4 you had your licence and yes i do ALL my work thank you. and YES burning oil causes black dust in your pipes, dumb ***!
Old Feb 18, 2004 | 03:29 PM
89EF9's Avatar
retard your timing. this will also help to pass an emissions test. (EXcl. CA)
Old Feb 18, 2004 | 07:31 PM
rukawa1one's Avatar
Default Re: (89EF9)
ya I'm running a cat and no my exhaust is not smelling like rotten eggs. Anyways, I changed my plug wires to stock today, just traded my 9.3's with some guy i know at work. the idle feels smoother, but im gonna go to the junkyard next week and pick up o2 sensors from a 2000 civic so it will be as new as possible. Hopefully that will fix the problem. if that still dont work, im gonna rip out this engine and put in a new one!! haha easier said than done. Oh by the way, I had that FPR on for ever since 98 till middle 03, so u think they would have destroyed my o2 readings?
Roca fella Bryan
Nov 9, 2007 09:09 AM
Linh.
17
Mar 1, 2006 12:47 PM
benjaminenjamin
Dec 5, 2004 04:53 PM
E Swift
Jul 27, 2003 01:57 PM
b18c1delly
Aug 16, 2002 08:02 PM
