question on wastegate fitment..
Old Feb 17, 2004 | 07:15 PM
J337_UNIT's Avatar
Default question on wastegate fitment..
being that i purchased a 4 bolt t3/t04e turbo, im going to go with the MAXREV log style manifold.. These manifolds come with a flange for a 35mm tial wastegate, however i would rather put a 38mm on because im only looking to boost 8-10psi .. now my question is, what would i do about this..the flages wont line up right will they? any advice, or would i be ok with the 35mm gate. TIA
Old Feb 17, 2004 | 07:17 PM
twkdCD595's Avatar
Default Re: question on wastegate fitment.. (J337_UNIT)
38 fits a 35 flange I believe.
I would try the 35 first though, if it has issues change it.
Old Feb 17, 2004 | 07:22 PM
J337_UNIT's Avatar
Default Re: question on wastegate fitment.. (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">38 fits a 35 flange I believe.
I would try the 35 first though, if it has issues change it.</TD></TR></TABLE>
well the problem is i dont have a wastegate yet, and i dont want to buy one then realize i shoulda got the other...
EDIT: Just found a few threads on this, twkd you were right..38 and 35mm use the same flange, thanks
Old Feb 17, 2004 | 07:28 PM
DaX's Avatar
DaX
Loved
Community Favorite
You should be fine using either 38 or 35. TiAL actually says that the lower you boost the larger your wastegate should be. I'm running a 40mm TiAL, but I'm boosting low numbers with the hopes of boosting higher numbers later.
Old Feb 17, 2004 | 07:34 PM
J337_UNIT's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">You should be fine using either 38 or 35. TiAL actually says that the lower you boost the larger your wastegate should be. I'm running a 40mm TiAL, but I'm boosting low numbers with the hopes of boosting higher numbers later.</TD></TR></TABLE>
yea i understand that, but i figure the 38 is the perfect medium for my set up..8-10 psi now 14+ next year on built bottom and no need to change wastegate
Old Feb 17, 2004 | 07:36 PM
DaX's Avatar
DaX
Loved
Community Favorite
Agreed. I just went with the 40mm for the bling factor.
Old Feb 17, 2004 | 07:54 PM
Silverbeast's Avatar
35 and 38 flanges are the same. I know i switched from a 35 to a 38 on that same maxrev manifold.
Old Feb 17, 2004 | 09:17 PM
MikeMAN's Avatar
35mm and 38mm flanges are identical, the only difference is the 38mm has a 38mm diaphram.
mike
Old Feb 17, 2004 | 09:41 PM
twkdCD595's Avatar
Default Re: question on wastegate fitment.. (MikeMAN)
if you dont already have the wastegate I would go ahead and get the 38... I have a 35 now and want to change to the 38 hp when I get the change.
SI_frankenstein
Jul 8, 2011 12:05 PM
zach1288
Mar 23, 2010 06:04 AM
Mr. Vapor
Welding / Fabrication
12
Feb 10, 2006 02:36 PM
1RMDave
Nov 16, 2004 02:17 PM
accordfreak
Aug 29, 2003 03:39 AM
