4000rpm idle
Old Feb 17, 2004 | 05:25 PM
89b16hf's Avatar
Default 4000rpm idle
took my perfect running b16a out of my crashed hf but it my new si now its idling at 4000
Old Feb 17, 2004 | 05:59 PM
jedubz's Avatar
Default Re: 4000rpm idle (89b16hf)
Make sure the hoses on your intake manifold are still connected. TPS sensor included. Check for CELS.... Not to mention check out your throttle cable (press with your finger to give it some slack and if the idle drops to normal, theres your answer)
Old Feb 17, 2004 | 07:31 PM
B2FiNiTY's Avatar
Check what he said above. Make sure all the vacuum hoses are on and are not leaking. You can pinch or remove them to see if affects anything.
Sounds like the throttle cable is stuck open.
ONECLEAN91
Mar 16, 2011 04:58 AM
Hackura
Mar 12, 2009 03:17 PM
EJuno
Jan 29, 2008 06:23 PM
haroldthefly91crx
Mar 31, 2007 02:09 PM
crx-si
10
Jan 30, 2003 07:26 AM
