tools needed for ex front brake swap to 94 dx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS-Rcivic »</TD></TR><TR><TD CLASS="quote">its called a fork, basically a long piese of stell with a snake tounge like end
</TD></TR></TABLE> Negative, you're referring to a pickle fork. DO NOT use this unless you are planning on replacing the balljoints as this tool WILL rip the boot. Use a puller i.e. pitman arm puller, etc.
suspension bushings have nothing to do with the ball joint boot
and yes you can use a pickle fork but if you rip a boot you will have to buy a new one and re pack the joint with grease.
a pitman arm puller works very well but they cost quite a bit more than a pickle fork
also you must bleed your brakes after doing this (common sense) but i will tell you right now, when you upgrade your calipers your brakes will SUCK unless you also upgrade your Master Cylinder and Brake Booster and for that you will need a INVERTED FLARING TOOL (so whenyou put the larger fitting on the line you can re flare the line so it will seal)
this is a job for a person with a good bit of knowledge of how the brake system functioons and how to diagnos it.
i would definately reccomend having someone that has done this before help you or pay someone to do it for you, because the last thing that you want to fail is your brakes.
madmanmaigret
13
Aug 1, 2007 05:09 PM
jonnydbagz
Jun 15, 2007 03:42 PM
blackccoupe
Feb 17, 2004 05:44 PM
