CAr Dies for no reAson/....!!
Old Feb 17, 2004 | 05:09 PM
ENeRg3Tic's Avatar
Default CAr Dies for no reAson/....!!
can somebody please help me find a solution??
i have a b16a, second gen head w/ first gen manifold, and first gen block
ok my car will start fine and run ok if i push the gas but wen i let off and the idle drops all the way to ZERO and turns off and then it starts fine again......
cleaned the iacv and tighten the fitv.....no vaccum leaks and tightened bolts to the TB.....map sensor is ok...TPS needs adjustment but it souldn't die.....
HELP
can this be caused by the pcv valve ???
Old Feb 17, 2004 | 05:25 PM
RedlinedVTEC's Avatar
Default Re: CAr Dies for no reAson/....!! (ENeRg3Tic)
PCV valve will not cause this. Are you throwing any codes? What is your fuel pressure at and also what plugs are you running (almost sounds like the spark is being blown out). When you say TPS needs adjustment what leads you to believe this?
Old Feb 17, 2004 | 06:28 PM
ENeRg3Tic's Avatar
Default Re: CAr Dies for no reAson/....!! (RedlinedVTEC)
no Codes...dont kno wat the pessure is and the plugs were replaced like a year ago...TPS needs adjustment because i was messing wit it
Old Feb 17, 2004 | 06:35 PM
PnX-R's Avatar
When you say TPS needs adjustment, do you mean the sensor itself or the throttle blade.. Because you're not suppose to adjust the throttle blade.
As for it dying after you let off the throttle, I'd say your throttle blade is closed too far.. If it's too tight not enough vacuum can get through to keep the engine running..
Old Feb 17, 2004 | 06:46 PM
ENeRg3Tic's Avatar
Default Re: CAr Dies for no reAson/....!! (PnX-R)
the TPS sensor... wat is the throttle blade??
wat do you think i should do then??
Old Feb 17, 2004 | 11:31 PM
see_our_vtec's Avatar
i'm having the same problems too. any more info on what to diagnose would be appreciated.
Old Feb 18, 2004 | 01:37 AM
eyeamvic's Avatar
Well since you say you messed with the TPS, why not try and adjust that first to see if it's the problem? That'd be the first thing I'd try.
Old Feb 18, 2004 | 02:29 AM
MrParks's Avatar
what car do you have? crx or civic ?88-91 92-95- 96-00 ? if you have a 88-91 rex was it a dx hf si? if you have this car you need to apply 12v to your iacv on the ylw blk wire if that makes sens to you this should slove this problem if you own an later model you are using the wrong int mani... also if this is true your injectors need replacement for and obd1 type gray plug hope this is useful info goood luck bro
Old Feb 18, 2004 | 05:56 PM
ENeRg3Tic's Avatar
Default Re: (eyeamvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eyeamvic &raquo;</TD></TR><TR><TD CLASS="quote">Well since you say you messed with the TPS, why not try and adjust that first to see if it's the problem? That'd be the first thing I'd try.</TD></TR></TABLE>
That is the first thing i tried but i kno that is not the problem it may contribute to it but not it
Old Feb 18, 2004 | 06:54 PM
TIRENECK's Avatar
Default Re: (ENeRg3Tic)
i had a similar problem and it was my distributor going out.
Old Feb 18, 2004 | 09:14 PM
PnX-R's Avatar
If your Throttle Blade has been screwed with, it is said that you must perform a Minimum Air Flow setting.. To do this, you have close the Blade by backing off the screw. After that you need to open the Blade one to two turns. This will allow a small amount of air to get in. From there you adjust it to get idle to specs..
ILcrxsi1
Honda Civic (2001 - 2005)
82
May 4, 2016 04:55 PM
LukieLuc
Mar 14, 2008 11:49 AM
jakscivic
Apr 3, 2006 05:42 PM
loudsubz
Mar 26, 2006 04:11 PM
NONKonformyst
Jan 31, 2002 02:31 PM
