Seat brackets wont line up...bolting alternative??? Please help!
Old Feb 17, 2004 | 04:45 PM
AgentJam's Avatar
Default Seat brackets wont line up...bolting alternative??? Please help!
Okay the Si seats i have in my 88 Dx never fit right and since i had the car were only held in by 3 bolts each. They were very hard to move forward and back and the passenger side seat was actually stuck. After taking some bolts off i realized that they were bolted cruked. I moved the rails adn aligned them so the seat will slide but now i can't get 2 of the bolts back in because the holes are off. I can't just force them in or i will be back where i started with an unmovable seat. Has anyone every used metal screws to just screw into the floor? or any kind of metal sinkers?
Please Help! and I thank you in advance!
Vince
Old Feb 17, 2004 | 04:50 PM
EL Vap133's Avatar
Default Re: Seat brackets wont line up...bolting alternative??? Please help! (AgentJam)
What year Si seats are they?
1's Avatar
Use 88 seat rails. they are different than 89-91.
Old Feb 17, 2004 | 05:00 PM
GoFastMotorSports's Avatar
Default Re: Seat brackets wont line up...bolting alternative??? Please help! (1)
I'm pretty sure 88-89 are the same. I had the EXACT problem you have. I got 90-91 SI seats and rails, I ended up using my 88 DX rails and drilling new holes into the seats and bolting down. I would probally easier to use 88 dx rails. IF you have 90-91 si seats I don't think 88-89 si rails will bolt up straight either,
Old Feb 17, 2004 | 05:03 PM
1's Avatar
Default Re: Seat brackets wont line up...bolting alternative??? Please help! (GRCCRX911)
89-91 are different than 88!
Old Feb 17, 2004 | 05:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 &raquo;</TD></TR><TR><TD CLASS="quote">89-91 are different than 88!</TD></TR></TABLE>Your right,my bad,I had 89 SI seats,but my statement still applies.
Old Feb 17, 2004 | 05:11 PM
EL Vap133's Avatar
Only 3 bolts from the 91 Si seats that I had lined up with the holes in my 88 crx......
Old Feb 17, 2004 | 05:19 PM
AgentJam's Avatar
They must be 89 because i know they aren't 90-91...my si seats dont have red stitching like my friends. I looked under the seats and the rails on there now were welded on...just looks like they weren't welded on right! I found a thread where someone drilled through the floor and through the underbody and put a bolt all the way through with a washer so it could be tightened from under the car. Seems like what i might end up doing.
I'm also looking at either getting my seats re-upholstered with leather or buying a new set of something nice...rsx/gsr/type r/newer si? i dunno haven't done to much research...but if i stick with these seats i have to work something out...
Vince
Old Feb 17, 2004 | 05:26 PM
EL Vap133's Avatar
My 91 Si seats had red stitching, can you post pics of yours?
Old Feb 17, 2004 | 05:42 PM
AgentJam's Avatar
Default Re: Seat brackets wont line up...bolting alternative??? Please help! (EL Vap133)
Old Feb 17, 2004 | 05:49 PM
EL Vap133's Avatar
Oh, those look like the same seats my friend has in his 88 Si crx...
Old Feb 17, 2004 | 06:01 PM
b16_madman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRCCRX911 &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure 88-89 are the same. I had the EXACT problem you have. I got 90-91 SI seats and rails, I ended up using my 88 DX rails and drilling new holes into the seats and bolting down. I would probally easier to use 88 dx rails. IF you have 90-91 si seats I don't think 88-89 si rails will bolt up straight either,</TD></TR></TABLE>
i wished i had thought to drill into the seats and not the floor!
I've got 90-91 Si seats in my 88dx. I am using the 88 inner seat rails and the 90-91 si outer rails.
Inners bolt up to the original holes, but for the outers I drilled thru the floor, used some washers, and 1/4" thick steel backing plates. It's not loose or anything, but if I could do it over I'd try the drill into seat mod.
here's 90-91's from the si hatch, but i assume crx one's are the same, well minus the chunk missing from mine
Old Feb 18, 2004 | 04:23 AM
AgentJam's Avatar
Default Re: Seat brackets wont line up...bolting alternative??? Please help! (B16_madman)
Anyone have some 88 dx rails...
Old Feb 18, 2004 | 06:31 AM
andrew dc's Avatar
swap buckets and rails!!!!
done deal!
Old Feb 18, 2004 | 02:46 PM
Destroyer24Seven's Avatar
Another difference could be if you have Si hatch seats going into a crx. Or vice versa I know that the rails are different in crx than hatch.
Old Feb 18, 2004 | 02:53 PM
AgentJam's Avatar
Default Re: (Destroyer24Seven)
yeah i don't know what i'm going to do because i just got a quote on reupholstering them...$700 for cloth, $950 for leather. Might as well buy some S2000 seats!!!
By the way does anyone know if '03 civic Si seats fit in a crx? or do they sit too high..
Vince
hondateg10
Aug 8, 2008 06:18 AM
Expletive!
Jan 18, 2006 01:04 AM
CilveReX
May 14, 2004 05:55 PM
Erik_Pb_Foot
Aug 11, 2001 07:49 AM
