Got a question for those using 215 width tires.
Old Feb 17, 2004 | 04:43 PM
Si's Avatar
Si
Default Got a question for those using 215 width tires.
I need to know which tire size would work better without throwing the speed sensor off much, a 215/40-17 or a 215/45-17 size tire, also would the 215/40's be thick nough to avoid bending the wheel on the first pothole you run since I'll probably get the yoko parada spec2's.
Old Feb 17, 2004 | 04:59 PM
Si's Avatar
Si
Default Re: Got a question for those using 215 width tires. (Si)
did some more research, the 215/45-17 keeps the speed sensor closer to spec and it's also better for ride comfort and to avoid wheel damage.
Old Feb 17, 2004 | 05:43 PM
crxagogo's Avatar
...that's (215/45/17) what I'm running on my Sub-zeroes. Rides like stock with my Eibach prokit
Old Feb 18, 2004 | 01:25 PM
LOSERgirl's Avatar
I have the 215/45/16 Azenis tires which still thows off the speedo (speedo says you are going 70 but you are really going 65)......with the 215/40/16 you can feel every bump on the road........
Old Feb 18, 2004 | 08:03 PM
VTECdTypS's Avatar
is it the width of the tire or the side profile that throws off the speedo or both
is there anyway to fix soemthin like that
Old Mar 4, 2004 | 12:40 PM
LOSERgirl's Avatar
Default Re: Got a question for those using 215 width tires. (VTECdTypS)
There is a calculator on the net that shows you how much your speedo will be off plus or minus if you use a different tire size http://www.miata.net/garage/tirecalc.html there isn't a way to fix it...........
Old Mar 4, 2004 | 01:24 PM
fireant's Avatar
Default Re: Got a question for those using 215 width tires. (LOSERgirl)
Its the diameter that changes the speedo reading.
This can be potentially confusing for some of us here, since the stock tire diameter for the RSX and the Si is different.
The same 215/45/16s on my EP3 only throw the speed off by 2.5%... meaning when MY speedo says 70, Im going 68.25.
Seks
Honda CR-V & Element
Nov 10, 2012 08:51 PM
mikeaitken
Sep 11, 2007 01:41 PM
raymondcleung
Sep 13, 2002 07:38 PM
Bbasso
Aug 19, 2002 11:02 PM
1tuffex
Mar 16, 2002 12:54 PM
