Need some F/R spring rate info(H22/EG hatch)!!!!
What are some good spring rates to go with this setup? Needs to be streetable and also work at the strip. I will probably be runnin kyb gas adjustables. Progress Group offers 325F/200R...
use 850k to 1000k for the front and 800 k for the rear thats a good set up for street driving with those shocks i recomend skunk2 92to 97 acc coil overs if you do it that way you can pick them up for about 225 to 275
