Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Rotora Big Brake Kits
Old Feb 17, 2004 | 12:13 PM
prostreetonline's Avatar
Default Rotora Big Brake Kits
Catered for the performance enthusiasts, Rotora introduces its premier big brake upgrade. Fully cast and CNC machined to ensure the highest quality; Rotoras 4 piston caliper brake kit system improves the pedal feel by increasing the clamping force while utilizing the stock master cylinder to ensure stock brake balance. Using this kit, end users receive a race-proven setup performance solution combined with an appealing aesthetic application.
Contents of Rotora Brake Kit
TWO 1 piece cross-drilled and slotted vented e-coated black rotors ( 330mm or 295mm, depending on applicaiton )
TWO 2-piece cast aluminum 4-piston calipers ( red or blue caliper of your choice )
TWO anodized black caliper mounting brackets
Rotora street performance pads
Stainless Steel braided brake lines ( DOT Approved)
All systems are ABS compatible, and direct bolt on replacement to all stock front suspension systems, with 15-25 percent larger surface area compared to stock.
Click here to order and for prices:
http://www.prostreetonline.com...+Kits
Old Feb 17, 2004 | 05:17 PM
mist sITR's Avatar
Default Re: Rotora Big Brake Kits (prostreetonline)
JW. what size wheel do you need to have to fit over these?
Old Feb 17, 2004 | 05:20 PM
Depends on application... usually at least a 17" wheel
Old Feb 18, 2004 | 02:14 PM
kameleongirl's Avatar
Default Re: (prostreetonline)
i'm looking for a complete set-up(front and back)
does stoptech make one??
i dont want to relocate my rear calipers, i need big ones in the back too!!
Old Feb 18, 2004 | 04:17 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Default Re: (kameleongirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kameleongirl &raquo;</TD></TR><TR><TD CLASS="quote">i'm looking for a complete set-up(front and back)
i dont want to relocate my rear calipers, i need big ones in the back too!!</TD></TR></TABLE>
No you don't
Old Feb 19, 2004 | 06:25 AM
b20turbojason's Avatar
Default Re: (91 Teg)
pm me with a price for a 96 civic dx hatchback. will these work on a civic with 16 inch wheels or is it 17 on all cars
Old Feb 20, 2004 | 05:22 AM
kameleonjrsc's Avatar
ttt
Old Feb 21, 2004 | 11:48 PM
JSJ EG6's Avatar
Default Re: (kameleonjrsc)
do they make rear's too?
Old Feb 22, 2004 | 12:34 AM
Sure do. Let me know what application you need it for.
Old Feb 22, 2004 | 01:39 AM
JSJ EG6's Avatar
check PM.
Old Feb 23, 2004 | 10:03 AM
Old Mar 1, 2004 | 07:19 AM
SOHC Gord's Avatar
wish i had the money they would be on my car
Old Mar 1, 2004 | 04:46 PM
AF_BRYAN's Avatar
Default Re: Rotora Big Brake Kits (SOHC Gord)
you have any for a 98 honda accord V6 Sedan?
Old Apr 1, 2004 | 09:20 PM
DC2*Integra's Avatar
Default Re: Rotora Big Brake Kits (AF_BRYAN)
how much for front and rear for 2001 gsr?
2LEM1
Suspension & Brakes
10
Dec 27, 2016 09:41 PM
prostreetonline
Oct 23, 2005 10:07 AM
94gsrIntegra
Sep 13, 2004 07:22 PM
