D16Y8 gsr/ls throttle body swap
Old Feb 17, 2004 | 08:07 AM
00civex's Avatar
Default D16Y8 gsr/ls throttle body swap
I searched the archives and couldn't find any kind of steps that must be taken to do this swap. I heard that you would have drill new bolt holes, is this true? if any body can tell me what must be done to do this swap that would be great thanks
Old Feb 18, 2004 | 10:02 AM
SOHC Gord's Avatar
Default Re: D16Y8 gsr/ls throttle body swap (00civex)
TTT
Old Feb 18, 2004 | 11:15 AM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: D16Y8 gsr/ls throttle body swap (SOHC Gord)
what are you asking? If the gsr or the ls tb will bolt up to the y8 IM?? from what i've heard no, but you can always ghetto rig it just get your y8 tb ported out , and there you go
Old Feb 18, 2004 | 11:23 AM
ELSpool's Avatar
yes they bolt up, GSR, B16A 1gen, and H22 are all 60mm, and the itr is 62. Great up grade for the Skunk2 manifold. If you don't have the new manifold and just have the Y8 IM mani, you will need to bore out the TB opening to port match.
Old Feb 18, 2004 | 11:50 AM
greebler's Avatar
Default Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">yes they bolt up, GSR, B16A 1gen, and H22 are all 60mm, and the itr is 62. Great up grade for the Skunk2 manifold. If you don't have the new manifold and just have the Y8 IM mani, you will need to bore out the TB opening to port match.</TD></TR></TABLE>
I confirm this, all honda B series TBs will bolt up fine. For all you fools that doubt us, read the SOHC thread that Spade did. You need to port match the TB to your Y8 mani, besides that its cake. Yes you can Dremel this if you want, just don't **** it up.
MLefPROJECT
11
May 30, 2007 06:04 PM
blinger
Mar 19, 2007 11:47 AM
DsMWookie
Sep 23, 2003 05:40 PM
ImAzn
Apr 28, 2003 05:22 PM
willyboyK20
Nov 24, 2001 04:41 PM
