CEL comes on intermittantly....??
Old Feb 17, 2004 | 08:03 AM
LoooseGSR's Avatar
Default CEL comes on intermittantly....??
Hey I just finished my B16 swap, and the car runs great...except that while driving the CEL will flash intermittantly fairly frequently, almost like it's keeping time or something, comes on when I hit bumps, accel, decel, kinda weird, i think it's a ground...but I'm not sure...
Old Feb 17, 2004 | 09:51 AM
CRXRageD's Avatar
Default Re: CEL comes on intermittantly....?? (PSUCRX)
have you tried checking the ecu for any LED flashes?
Old Feb 18, 2004 | 05:53 AM
LoooseGSR's Avatar
Default Re: CEL comes on intermittantly....?? (CRXRageD)
Yeah, the ECU isn't actually throwing a code...but the CEL keeps flashing on and off while I'm driving, car runs great though...I went through last night and checked all my grounds, found that 2 injector clips were missing so I replaced those and made sure all connectors were tight, adjusted idle(because it was sitting at 1500 to 2000 rpms). I really need to find out what's causing this, because I have a track event this weekend I don't want to miss...
Old Feb 18, 2004 | 07:30 AM
virginia_dude's Avatar
Yes thats odd you are getting a CEL with no codes being thrown. You can check the obvious and see if the wire for that is shorting out to something.
Old Feb 18, 2004 | 07:39 AM
LoooseGSR's Avatar
Default Re: CEL comes on intermittantly....?? (virginia_dude)
Wire for what? the CEL? I honestly don't know where to start finding that...I went over everything like I said last night...still no luck...is it possible that all the fiddling we did in the past few days(3 different ECU's one was bad one was a PM6 and the one in it currently has an aggressive fuel curve) The motor threw 3 different codes with the other ECU's and with this one, and since the last code, it has only been stopped and restarted...should I disconnect the battery to reset the ECU?
Old Feb 18, 2004 | 09:01 AM
Yes I would recomend that. Any valid error codes will return.
Old Feb 18, 2004 | 09:12 AM
LoooseGSR's Avatar
Any other ideas on what it could be???
kyang03
Mar 6, 2014 07:31 PM
91ef_civic
Mar 22, 2011 02:33 PM
circapunk
Jun 7, 2009 09:32 AM
Mr.Death
Sep 16, 2007 02:05 PM
B18EG6
Nov 8, 2002 07:22 AM
