JDM ITR 4-1 Header
Old Feb 17, 2004 | 12:19 AM
boszyen's Avatar
Default JDM ITR 4-1 Header
I just installed a JDM ITR 4-1 header, but it feels like it is losing some torque...
I don't know if it gained on the top end but VTEC sounds louder however I can't feel any difference... LOL
Can someone who has the above header clarify this? Will I see any gain later, coz my friend said that the ECU will adjust itself?
Thanks
Old Feb 17, 2004 | 12:52 AM
Downey's Avatar
Default Re: JDM ITR 4-1 Header (boszyen)
did it replace the stock oem header? try re-setting the ecu.
Old Feb 17, 2004 | 01:05 AM
Misfit's Avatar
Go do a before and after dyno and see the gains for yourself. just because your car sounds or feels different isn't a good judge of power.
Old Feb 17, 2004 | 01:06 AM
boszyen's Avatar
Default Re: JDM ITR 4-1 Header (Downey)
yes it was replacing the stock 4-2-1 Australian ITR header...
actually the 4-2-1 header was modified...
I asked an exhaust shop to remove the restriction (just after the 2-1, there is a tapering pipe decreasing in diameter and then increasing to normal size just before the flange) <= I removed that and the small flange
It gained noticable mid range and a little bit on the top end.
BUT there is not much difference with the new JDM 4-1 header, except for the sound at VTEC
I'll try resetting the ECU anyway
thanksssssss
Modified by boszyen at 8:17 PM 2/17/2004
Old Feb 17, 2004 | 02:51 AM
Bbasso's Avatar
I'll pay you 100 for that lousy header.
Butt dyno's suck 90% of the time.
Old Feb 17, 2004 | 07:57 AM
rainman's Avatar
Default Re: JDM ITR 4-1 Header (Bbasso)
Of course you're going to lose out on torque with a 4-1 header. The gains will be in top end HP whereas a 4-2-1 header gives you better torque.
Old Feb 17, 2004 | 08:41 AM
Chris N's Avatar
Default Re: JDM ITR 4-1 Header (rainman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainman &raquo;</TD></TR><TR><TD CLASS="quote">Of course you're going to lose out on torque with a 4-1 header. The gains will be in top end HP whereas a 4-2-1 header gives you better torque.</TD></TR></TABLE>
This generalization is almost always not true....
lilo_goki
Feb 7, 2008 12:09 PM
si90rex
Welding / Fabrication
Feb 21, 2007 05:41 AM
vtec8804
Feb 13, 2007 01:17 PM
Screamer
12
May 9, 2004 03:35 PM
vtecmuscle
Sep 16, 2002 07:47 PM
