battery draining over night help!!!
Old Feb 16, 2004 | 10:43 PM
imnotswapped's Avatar
Default battery draining over night help!!!
yea my fren got b16 and like in the mornin he says that the battery got weaker like its bout to die he said like the batery drained overnight wut could be the reason for this fuses or bad wireing i really dont noe wuts wrong so plz help
Old Feb 16, 2004 | 10:51 PM
Default Re: battery draining over night help!!! (GoT HaTcH#2)
oh yea he jump started the car and he droved it went smooth. when he accelerate the lights get brither and when he hits a bump the lights get dimmer and brighter need help!! thanks
Old Feb 16, 2004 | 11:01 PM
North_Texas's Avatar
Ugh why doesn't he get a new battery or charge the hell out of it. Sounds like it's
drained, is it cold there?
Old Feb 17, 2004 | 12:44 AM
Xsi's Avatar
Xsi
Could be that the battery has just died, that happens sometimes. Swap it with a battery you know is good and see what happens
Old Feb 17, 2004 | 02:12 AM
99b18's Avatar
proly got a dead cell in thebattery. change the battery. u can check it with a meter. should be at least 12.4v. for a good battery.
Old Feb 17, 2004 | 06:03 AM
88whitehf's Avatar
If you say that the battery died overnight the thing that i would suggest is that its the battery or the alternator. The alternator might not be charging the system. IF you were to check the battery for voltage the battery is good if its over 10 volts. A new battery will have approximately 12.6 most batteries dont have that though. If its really cold in your area you battery could be just getting to cold. I know where i am its damn cold. check the battery for voltage if that is not ok try charging is so it is within specs, if it drains then replace your alternator. and it wouldn't hurt for a battery either. You can add water to the battery cells, most batteries have tabs on them pop those off and look to see if you can see acid/water in the cells and fillem up.
chris
Old Feb 17, 2004 | 08:18 AM
PupaScoopa's Avatar
Default Re: battery draining over night help!!! (88whitehf)
Have the battery and charging system tested at an Advance auto parts or Autozone.
Old Feb 17, 2004 | 08:27 AM
Turbo E's Avatar
how old is the battery? 5 years is about the limit.
Old Feb 17, 2004 | 10:03 AM
12thstreetjunkman's Avatar
Prolly is the battery, but if you want to check for a draw, get a small 12v light socket, connect a aligator clip to each end, dissconnect the negative battery terminal, and connect one end of the bulb socket to the negative battery cable, the other end to the battery post, so the car is grounding through the bulb. The bulb should emit no light, if it does start disconnecting stuff or pulling fuses till it goes out. I work at a stereo shop and we have to do this all the time for customers complaining of draining batteries, hope this helps.
Jizzo
Dec 18, 2007 03:43 PM
dog the bounty hunter
Feb 5, 2006 11:50 AM
BB4vTak
Nov 14, 2005 01:05 PM
CivicBoi
Oct 4, 2003 12:46 AM
