How to preload drivetrain with 2step?
Old Feb 16, 2004 | 10:35 PM
turtle-eg's Avatar
Default How to preload drivetrain with 2step?
For all the people here who recommend preloading the drivetrain at the line, is it possible to do it with a 2step? If it is possible, what's the highest rpm it can be done at, cuz' holding the rpms at 8000 slipping the clutch seems like a killer for the clutch....
Also, when do you start your preload, when the other guy's staging lights turn on?
Old Feb 17, 2004 | 01:35 AM
Kwuaymaikrup's Avatar
Default Re: How to preload drivetrain with 2step? (turtle-eg)
*Rob Schnider voice* You can do it!!!! *Rob Schnider voice* It won't be too bad on the clutch as long as you are only loading just enough to keep a little tension on the trans. Don't load it soo much that the *** end squats.
-Ryan
Old Feb 17, 2004 | 05:53 AM
93hatched_projekt's Avatar
Default Re: How to preload drivetrain with 2step? (Kwuaymaikrup)
Stopid nood question , but I always here people talking about preloading the drivetrain. What does that mean and what does it do , just curious.......thanks
Old Feb 17, 2004 | 07:29 AM
GRTechnologies's Avatar
Default Re: How to preload drivetrain with 2step? (93hatched_projekt)
your are going to need some kind of a line lock or a staging break to truly preload your car
Old Feb 17, 2004 | 07:33 AM
SpoolnG2's Avatar
Not positive, but i think they mean once you get to the line, you let the clutch out right to the point where you can feel its just about to grab but it doesnt move the car yet. This way there is a little pressure on the internals and you go from some pressure to a lot of pressure over nothing at all to everything. Its probably easier on the trans.
Old Feb 17, 2004 | 08:32 AM
Jokerluv's Avatar
Default Re: How to preload drivetrain with 2step? (GRTechnologies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRTechnologies &raquo;</TD></TR><TR><TD CLASS="quote">your are going to need some kind of a line lock or a staging break to truly preload your car</TD></TR></TABLE>
i pretty sure a line lock is illegal to use when launching a car
Old Feb 17, 2004 | 09:21 AM
kevinoneill's Avatar
Default Re: How to preload drivetrain with 2step? (Jokerluv)
Pre-loading: Hold the e-brake up, let clutch up just enough so you can feel the car pull, while holding the revs at what ever you want to launch at. You drop the cluth and the e-brake at the same time. Off you gooooo!
Old Feb 17, 2004 | 11:52 AM
J.R.'s Avatar
Default Re: How to preload drivetrain with 2step? (issues4)
Would it matter if you did it without holding the ebrake? I never use the ebrake.
Old Feb 17, 2004 | 12:21 PM
dmotoguy's Avatar
Default Re: How to preload drivetrain with 2step? (J.R.)
i think his question deals with the fact that the two step runs off of a clutch switch.. can you slightly let off the clutch to preload the drivetrain while still having the 2step activated keeping your rpms at your launch point.
Old Feb 17, 2004 | 01:05 PM
yimmy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.R. &raquo;</TD></TR><TR><TD CLASS="quote">Would it matter if you did it without holding the ebrake? I never use the ebrake.</TD></TR></TABLE>
If you dont use the ebrake you wont get much of a load at all. And you will probably pass the timer.
Old Feb 17, 2004 | 01:19 PM
J.R.'s Avatar
Default Re: How to preload drivetrain with 2step? (yimmy)
I am going to try this next time I'm at the track, Thanks.
Old Feb 17, 2004 | 02:18 PM
JDM2ndGen's Avatar
Default Re: How to preload drivetrain with 2step? (dmotoguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy &raquo;</TD></TR><TR><TD CLASS="quote">i think his question deals with the fact that the two step runs off of a clutch switch.. can you slightly let off the clutch to preload the drivetrain while still having the 2step activated keeping your rpms at your launch point.</TD></TR></TABLE>yea i was wondering this also ...and what is a line lock ...i never heard of one ...
Old Feb 17, 2004 | 02:47 PM
dmotoguy's Avatar
Default Re: How to preload drivetrain with 2step? (JDM2ndGen)
line lock holds brake pressure after you let off of the pedal until you let go of the button.. used on domestic cars to do burnout. most import guys just use a staging brake/e-brake
saso
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jokerluv &raquo;</TD></TR><TR><TD CLASS="quote">
i pretty sure a line lock is illegal to use when launching a car </TD></TR></TABLE>
Umm why is a line lock illegal ? Is this some new rule?
Old Feb 17, 2004 | 02:50 PM
servion's Avatar
I thought that line locks were designed for drag racing....
Old Feb 17, 2004 | 03:07 PM
JDM2ndGen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmotoguy &raquo;</TD></TR><TR><TD CLASS="quote">line lock holds brake pressure after you let off of the pedal until you let go of the button.. used on domestic cars to do burnout. most import guys just use a staging brake/e-brake</TD></TR></TABLE>i gotcha now ...thanks for the info
Old Feb 17, 2004 | 05:21 PM
Big_Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jokerluv &raquo;</TD></TR><TR><TD CLASS="quote">i pretty sure a line lock is illegal to use when launching a car </TD></TR></TABLE>
line locks are not illegal, they actually do not work as well for those of us relying on the front wheels, a staging brake is the way to go, but if you are gonna use a 2 step put the button on the brake handle!!
ludekid4323
Feb 12, 2008 11:28 AM
InTeGrA_bLazEd
Mar 28, 2005 08:19 AM
Pure Sol
Feb 15, 2005 03:13 PM
DaveF
Nov 24, 2004 08:19 AM
