S1/YS1 Gear shafts into S80 tranny case????
Hey guys..
I´m planing to build a new transmission for my b20/v-tec turbo engine. I´ve already a 95 Integra LS transmission (S80) but there are some parts missing like the shift forg and a complete counter shaft with gears. The case is complete...
Now I want to know if it is possible to put the 2 gear shafts of a USDM 90-93 Integra cable transmission( S1/YS1 ) into the hydraulic tranny case. I want to have very long gear ratios thats the reason why I want to install these gears. I know it would be much easier to install the complete cable transmission but I don´t want a cable one ..I want a hydraulic tranny.
Whats about the LSD. I also want to buy a quaife LSD. I don´t know for what kind of car... Integra LS 94+ or 90-93 USDM????´
Thanx for your help
If anybody has better ideas about to getting longer gear ratios please tell me.
Thanx for your help
To begin with, the 2nd gen integras came with 2 very different transmission designs. The 92-93 cable trans is the only one with internals like the newer hydro box; the 90-91 internals will not be compatible. So, the YS-1 is the transmission you want to check out as a possible swap candidate.
What I would do next is check out http://www.acuraparts247.com, which will give you the part #s along with diagrams of the various gearboxes. Compare #s and see what's the same - lots of things will be. I know the newer internals will go in the 92-93 case, as I have swapped a hydro GSR gearset and Type-R LSD into a 92 case myself, so I assume the older gears would work in the newer case as well.
I would be careful mixing gears, though - the safe way is to use both the main and counter gear from one trans for each pair unless you're sure they are the same (part # comparison).
The quaife you'll want to check out is the 92+ LS model (they should be the same 92 and up; GSR is different). And you'll *need* the Helm manual.
Also, I've got lots of extra parts from my swap if you need anything.
