d16y7 with y8 intake mani legality ?
Old Feb 16, 2004 | 10:10 PM
deviant1's Avatar
Default d16y7 with y8 intake mani legality ?
is it legal (smog) in california to put a d16y8 intake manifold on a d16y7? i know in cali, you cant have a ls/vtec or crvtec cause you cant mix and match heads and blocks. but what about just the intake manifold?
Old Feb 17, 2004 | 06:50 PM
deviant1's Avatar
Default Re: d16y7 with y8 intake mani legality ? (deviant1)
bump
Old Feb 17, 2004 | 06:55 PM
Ricey McRicerton's Avatar
I don't see why it would'nt pass. It retains all of the same sensors and such. As long as you are putting a 96-98 IM on a 96-98 block and 99-00 the same way due to the extra air injection holes.
Old Feb 19, 2004 | 10:07 AM
deviant1's Avatar
Default Re: d16y7 with y8 intake mani legality ? (Ricey McRicerton)
bump for more opinions
Old Feb 19, 2004 | 10:11 AM
wdskuk's Avatar
Will it make a big difference by putting in a y8 intake mani. Also would anytihng else be needed to make it work.
Old Feb 19, 2004 | 10:26 AM
mooseknuckle's Avatar
Default Re: (wdskuk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdskuk &raquo;</TD></TR><TR><TD CLASS="quote">Will it make a big difference by putting in a y8 intake mani. Also would anytihng else be needed to make it work.</TD></TR></TABLE>
made a big difference on my y7. Best upgrade for a y7.
the skunk2 d-series IM is nice also. I kinda want one, but dont feel like going threw the trouble of putting it on. im lazy
Old Feb 19, 2004 | 09:03 PM
wdskuk's Avatar
What you mean moose. Isn't it the same way to put a y8 manifold on. Same as the skunk 2 one
Old Feb 19, 2004 | 09:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdskuk &raquo;</TD></TR><TR><TD CLASS="quote">What you mean moose. Isn't it the same way to put a y8 manifold on. Same as the skunk 2 one</TD></TR></TABLE>
its the same installation, but its just a pain in the ***. and im lazy.
i heard the skunk2 has a little better power gain, and im boosting so i kinda wanted a better flow. its all talk. I prolly wont even bother swapping on IM.
Old Feb 19, 2004 | 10:39 PM
deviant1's Avatar
Default Re: (mooseknuckle)
is the skunk IM for the y7 50 state carb legal or whatever? and is it like the y8 manifold that has the throttle body on the side and not on top of the manifold?
Old Feb 19, 2004 | 11:15 PM
Default Re: (deviant1)
If concerned about passing inspection, the y8 intake manifold and the skunk2 will pass. Last July I went and pass with flying colors.
Both y8 and s2 manifolds house a horizontal throttle body.
Your current manifold looks like this.. (my motor when stock)
Once you replace with either a y8 manifold from the 96-00, or a skunk2 d-series IM, it will look like this.. (after the y8 mani swap)
Notice: the tb position. and runners. Better air flow.
Hope this helps a little. not much of a tech.
Drew
Old Feb 20, 2004 | 03:39 PM
deviant1's Avatar
what state was this in?
lorenzookc
May 22, 2011 04:37 PM
jksmith
Sep 9, 2010 11:35 AM
menappi
Oct 9, 2006 05:25 PM
silver99
Jun 5, 2003 02:45 PM
BoostedD15B7
May 16, 2003 06:53 PM
