nsx calipers
Old Feb 16, 2004 | 10:08 PM
drunknbass's Avatar
Default nsx calipers
how good are nsx calipers?
are they better than prelude/accord/or type r calipers?
just wondering cause i was thinking about getting some for the civic
Old Feb 16, 2004 | 10:10 PM
GolfballSi's Avatar
Default Re: nsx calipers (drunknbass)
there was a thread pretty recently. legend calipers are same/slightly better.
Old Feb 16, 2004 | 10:11 PM
Filliam H. Muffman's Avatar
NSX = Heavy
Civic= Light
NSX brakes = Good for NSX
NSX brakes = bomb *** for civic.
Old Feb 16, 2004 | 11:01 PM
MiXeD Up CiViC's Avatar
I have a set on my civic and I love them. Braking is amazing.
Old Feb 16, 2004 | 11:52 PM
slammed_93_hatch's Avatar
they are a 2 piston caliper which means there clamping force is more then the ITR caliper. there heavier and bigger. they are about 10-15mm thicker then the 10.3 inch calipers. which means you will really have to watch which wheel you go with. I think that with 5 lug ITR wheels you will be ok with the offset.
Remeber unless you are running a weird rotor you will need to get the early year NSX caliper. from 91 i belive. which is for the 11.1 inch rotor. all the other year NSX use bigger calipers.
but the question is do you really need them. an 11.1 inch rotor with ITR caliper and some good pads, in a civic it is highly unlikely to need any more power. the only thing you might experiance is fad which can be taken care of with some ducting
Old Feb 17, 2004 | 12:06 AM
B18bEK's Avatar
hehe, are they good? they come on one of the most expensive performance produced Honda's ... sure hope they are good
Old Feb 17, 2004 | 01:59 AM
elwood's Avatar
sorry to jack it up.......
but anyone know the cheapist place to get them?
if they were cheap I would think about doing it, but im
poor, and cant afford 400$ calipers I have no need for.
Old Feb 17, 2004 | 03:39 AM
JimmyAtlantis's Avatar
Default Re: nsx calipers (elwood)
I'm sorry to jack also and I'm not looking for instructions. I'm just wondering what kind of a process (labor on a scale from 1-10 and man hours) this is.
Old Feb 17, 2004 | 05:29 AM
B18bEK's Avatar
https://honda-tech.com/zerothread?id=734560
from what i understand its a very basic install if you get all the right parts. you can occasionally find nsx calipers on sale here in the classifieds .. and you could go to a junkyard to get the prelude / legend calipers
Old Feb 17, 2004 | 05:50 AM
BigZ88's Avatar
Default Re: (B18bEK)
my personal feelings.... go with a fast brakes/willwood kit.... lighter and better and depending on where u get the NSX's the fastbrakes will probably be cheaper, and a serious bolt on affair.
Old Feb 17, 2004 | 06:57 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Do a search under the user name shawnhayes and type in NSX calipers or Legend calipers.
There are Legend calipers that are the same as the NSx units if I recall correctly.
Old Feb 17, 2004 | 07:05 AM
drunknbass's Avatar
Default Re: nsx calipers (B18C5-EH2)
what about nsx rears? do these bolt up also? i know the nsx caliper is for a thicker rotor but thats not a prob.
also looking into aftermarket nsx calipers since theres prob more performance options out there..
the car needs to do nose wheelies
Old Feb 19, 2004 | 04:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Do a search under the user name shawnhayes and type in NSX calipers or Legend calipers.
There are Legend calipers that are the same as the NSx units if I recall correctly.</TD></TR></TABLE>
yes you are right tom the 94 legend fully loaded has the 11.1 rotor's with 2 piston calipers.
hummmm next time im home im gona see how much remanufactured one's are with a core.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorry to jack also and I'm not looking for instructions. I'm just wondering what kind of a process (labor on a scale from 1-10 and man hours) this is.</TD></TR></TABLE>
well if you have to ask then i don't think you should do it.
first off you need 11.1 inch rotors. which if you do some searching there is a VW that has a 4x100 lug pattern and 11.1inch diameter. don't remeber what VW it was but it starts with a C.
secondly you will have to either buy knew wheels or get extended studs and run spacers so that the wheels will clear the caliper. i think it might be dificult to get a 4x100 wheel in a high enough offset to clear the calipers. i have heard that TE37 to clear ITR calipers on a 4x100 lug pattern but again the NSX caliper is thicker then the ITR caliper.
third, you will have to deal with the issue of haveing enough pressure in you lines to get the two pistons to clamp. so that means changeing to a bigger MC and maybe a BB depending on what MC you use.
EDIT
well **** after reading shawn's post. haveing NSX calipers is just for bling bling. i think, i suck at science, and all that **** confuses me but i think i got the point that the ITR caliper has a better clamping force then the NSX.
Modified by slammed_93_hatch at 2:09 PM 2/19/2004
Toy Civic
Dec 13, 2011 05:12 PM
TheMuffinMan
Dec 31, 2007 09:56 AM
crj_lll
Mar 31, 2005 05:06 AM
NXSpoon
Jun 28, 2003 05:03 AM
