Flywheel worth it???
New User
One more question for the day...should i change my flywheel to a lightened version??? I really don't want to spend the money, but I don't want to ever have to take my tranny off again. Could you all lay out some pros and cons for me??? That would be much appreciated. Thank you.
IF you're a drag racer you can change to a type R flywheel which is 4lbs lighter than a GSR. That will make a difference. Your engine will rev a little easier.
I don't advise going with a lighter flywheel unless you are a roadracer/autocrosser and aren't concerned with off the line acceleration.
