will a 5spd tranny off a d15 bolt right up to a d15 that had a 4spd tranny
Old Feb 16, 2004 | 08:03 PM
SOHC Gord's Avatar
Default will a 5spd tranny off a d15 bolt right up to a d15 that had a 4spd tranny
is there any modifications u have to make
Old Feb 16, 2004 | 08:08 PM
OnebadJdmEg6's Avatar
From: being tracked by FAGS Docking PERCENTAGES, GAYFUKS
Default Re: will a 5spd tranny off a d15 bolt right up to a d15 that had a 4spd tranny (SOHC Gord)
it'll bolt right up and fit but then you'll need a 5spd linkage, 5 spd axles, and you posted in the wrong forum, you should've posted this in the tech forum
btw anybody might want to back me up on the linkage and axles?
Old Feb 16, 2004 | 08:24 PM
b18lsHaTcHBaCk's Avatar
axles should be the same but your prob right about the linkage, what kinda car is this on btw?
Old Feb 16, 2004 | 08:38 PM
SOHC_Brian's Avatar
Default Re: will a 5spd tranny off a d15 bolt right up to a d15 that had a 4spd tranny (b18lsHaTcHBaCk)
only the civic std came in a 4sp manual if i remember correctly. so its probably a 88-91 civic. and everything should bolt up fine.
Modified by lazyassbrian at 11:49 PM 2/16/2004
Old Feb 16, 2004 | 08:53 PM
SOHC_Brian's Avatar
Default Re: will a 5spd tranny off a d15 bolt right up to a d15 that had a 4spd tranny (lazyassbrian)
u know what, i just remembered something about the trans on the 88 having a different numbered spline than the 89-91 trans. whats years the car? but i know for sure the trans out of the 89-91 civics are interchangeable. also, since you're getting another tranny, might as well get an si tranny from an 89-91 civic or crx
Old Feb 16, 2004 | 09:08 PM
dohc boy 96's Avatar
B A N N E D
wrong forum
Old Feb 17, 2004 | 07:17 AM
SOHC Gord's Avatar
Default Re: will a 5spd tranny off a d15 bolt right up to a d15 that had a 4spd tranny (OnebadJdmEg6)
well thanks for the info sorry for the wrong forum
Old Feb 17, 2004 | 07:18 AM
SOHC Gord's Avatar
well thanks for the info sorry for posting in the wrong forum
Old Feb 17, 2004 | 07:19 AM
SOHC Gord's Avatar
i think the axles will work too the shift linkage is what i was wondering its a d15b1
Old Feb 17, 2004 | 07:21 AM
SOHC Gord's Avatar
its a 90 model thanks for the info
Old Feb 17, 2004 | 08:30 AM
SOHC_Brian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC Gord &raquo;</TD></TR><TR><TD CLASS="quote">i think the axles will work too the shift linkage is what i was wondering its a d15b1</TD></TR></TABLE>
it'll work fine now quit asking questions and get rid of the 4 speed
Old Feb 17, 2004 | 11:58 AM
SOHC Gord's Avatar
haha ill do it
Old Feb 21, 2004 | 04:26 PM
SOHC Gord's Avatar
vmm
Jun 25, 2004 08:54 PM
GHETTOassREX
May 27, 2004 05:32 PM
GayHatch
Apr 2, 2003 08:58 AM
89 CRX SI
13
Apr 22, 2002 09:21 PM
