injector wire colors...**quick solution**
Old Feb 16, 2004 | 07:29 PM
Rob!'s Avatar
Default injector wire colors...**quick solution**
for obd2 car...can someone please just go run out to your car and tell me the order of your injectors...i think i have them mixed up but not sure...i just need you to tell me that wire colors in order and be sure to tell me which way ur starting from. thanks a bunch
Old Feb 16, 2004 | 08:13 PM
Rob!'s Avatar
Default Re: injector wire colors...**quick solution** (EKsnatchback)
bump for some lazy *** people...geez
Old Feb 16, 2004 | 08:19 PM
IN VTEC's Avatar
I did you one better and called Ms. Cleo. She said:
1- yel
2- blu
3- red
4- brn
Old Feb 16, 2004 | 08:47 PM
Rob!'s Avatar
Default Re: injector wire colors...**quick solution** (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I did you one better and called Ms. Cleo. She said:
1- yel
2- blu
3- red
4- brn
there is 2 wires going to each...i need the combination of them and i need to know which way your going for example...
starting at timing belt side...
1: red/yellow
2: blue/brown
3: etc
4 etc
do you know what i mean? thanks...
Old Feb 16, 2004 | 09:02 PM
IN VTEC's Avatar
The "other" wire going to the injector should be teh same for all the injectors. I think it's yellow with a blk stripe (yel/blk).
Old Feb 17, 2004 | 07:25 AM
doublejz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">The "other" wire going to the injector should be teh same for all the injectors. I think it's yellow with a blk stripe (yel/blk).</TD></TR></TABLE>
1- yel
2- blu
3- red
4- brn
Old Feb 17, 2004 | 07:28 AM
Rob!'s Avatar
Default Re: injector wire colors...**quick solution** (doublejz)
if 2 of them swtiched is it going to cause my car to be slower?
Old Feb 17, 2004 | 09:25 AM
IN VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKsnatchback &raquo;</TD></TR><TR><TD CLASS="quote">if 2 of them swtiched is it going to cause my car to be slower?
Yes b/c the injector timing in relation to piston/valve events is going to out of phase. It'd be almost the same thing as a cylinder misfiring.
Old Feb 17, 2004 | 02:32 PM
mooseknuckle's Avatar
i got the same issue as robo, but on a d16y7
Mine are screwed up think.
I also dont have a blue wire. I got like 2 yel/yel i think.
Drew
Jdm_Newb_NYC
Feb 23, 2006 01:11 PM
91dx-92ex
Jan 22, 2006 02:46 PM
ivanson
25
Nov 15, 2005 09:04 PM
Magic Wheels
Jul 17, 2004 02:03 PM
