Hearing VTEC
Old Feb 16, 2004 | 07:13 PM
GreenEX's Avatar
Default Hearing VTEC
i cant hear my vtec kick in anymore. how can i check to see if its working? I used to here my intake when it kicked in but now no change in sound.
Old Feb 16, 2004 | 07:53 PM
H22CL's Avatar
are you saying that when you use to hear it that you didn't feel it also? If you dont hear or feel it then something might be wrong. check oil level.
Old Feb 17, 2004 | 12:08 PM
GreenEX's Avatar
Default Re: (H22CL)
checked oil its perfect. My friend has an EX also and i can hear it on his so we traded intake to see if i coul hear mine but nope. What else can i check?
Old Feb 17, 2004 | 12:52 PM
TIRENECK's Avatar
Default Re: (GreenEX)
hmm codes...
Old Feb 17, 2004 | 01:32 PM
B18C2_sedan's Avatar
Default Re: Hearing VTEC (GreenEX)
i never heard vtec from a sohc eng
Maybe all my friends rides are weak
Old Feb 17, 2004 | 02:18 PM
np0r's Avatar
Default Re: Hearing VTEC (B18C2_sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C2_sedan &raquo;</TD></TR><TR><TD CLASS="quote">i never heard vtec from a sohc eng
Maybe all my friends rides are weak</TD></TR></TABLE>
VTEC on SOHC engines can only be heard from under the hood meaning from the engine. With a SOHC VTEC engine u wont hear VTEC through the exhaust like DOHC engines. Maybe this is y?
Old Feb 17, 2004 | 02:51 PM
OTT's Avatar
OTT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenEX &raquo;</TD></TR><TR><TD CLASS="quote">i cant hear my vtec kick in anymore. how can i check to see if its working? I used to here my intake when it kicked in but now no change in sound.</TD></TR></TABLE>
hes implying that he used to hear it
Old Feb 17, 2004 | 02:55 PM
np0r's Avatar
Default Re: Hearing VTEC (OTT)
And the person i was replying implied that HE NEVER HEARD VTEC on his friends SOHC. So that is y i said that and that y i QUOTED him and not the post maker.
Old Feb 17, 2004 | 03:14 PM
GreenEX's Avatar
Default Re: Hearing VTEC (JDM2NR)
yes i used to hear it thourgh my intake. Like i could tell a difference but it seem like now its not working is there a way to check and see if its working?
Old Feb 17, 2004 | 03:53 PM
Jimmy's Avatar
Global Moderator
I think it's you tripping...
go buy a new car
Old Feb 17, 2004 | 04:29 PM
GreenEX's Avatar
Default Re: (USDMDC2)
its a 99 just doenst seem like vtec works
Old Feb 17, 2004 | 05:32 PM
OTT's Avatar
OTT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM2NR &raquo;</TD></TR><TR><TD CLASS="quote">
VTEC on SOHC engines can only be heard from under the hood meaning from the engine. With a SOHC VTEC engine u wont hear VTEC through the exhaust like DOHC engines. Maybe this is y?</TD></TR></TABLE>
My bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenEX &raquo;</TD></TR><TR><TD CLASS="quote">its a 99 just doenst seem like vtec works</TD></TR></TABLE>
is the CEL lit-up?
Was anything done to the car since it last worked?
Old Feb 17, 2004 | 05:39 PM
boostn420's Avatar
When was the last time you cleaned your air filter?
Old Feb 17, 2004 | 06:14 PM
GreenEX's Avatar
Default Re: Hearing VTEC (boostn420)
the intake i have on now i took off my friends car and we could here it good on his car. i switched it to see if i could hear it with his
Old Feb 17, 2004 | 07:11 PM
np0r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OTT &raquo;</TD></TR><TR><TD CLASS="quote">
My bad.</TD></TR></TABLE>
no problem
Old Feb 17, 2004 | 07:51 PM
95swappedsi's Avatar
i never heard it on my sohc either....you woulkd think that if it wasnt working it would throw a code.....i ahve had probs with my vtec soln but it throws a code i blew one up and sometimes it will throw the light and i reset the ecu and its fine.......so i duno
Old Feb 17, 2004 | 11:23 PM
jdmteg01's Avatar
have you always had a cold air?????
Old Feb 18, 2004 | 01:02 AM
Downey's Avatar
with a 3" short ram on my D16Z6 i could hear VTEC.. but once i converted it over to a 3" cold air, i couldnt hear it anymore. who cares about sound, as long as it still works.
Old Feb 18, 2004 | 01:26 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Hearing VTEC (Downey)
i hear vtec extremely loud on my single cam turbo.....
if your not throwing a code , your prolly trippin
Old Feb 18, 2004 | 01:33 AM
eyeamvic's Avatar
All SOHC VTEC owners need to hook up a VTEC light.
Old Feb 18, 2004 | 08:27 AM
jdmteg01's Avatar
i recently fabricated a cold air box similar to comptech for my 2001 Gsr integ and I cant hear vtec come on any more lol on a DOHC motor but I can feel it....
Old Feb 18, 2004 | 08:36 AM
mattssi's Avatar
If you cant hear it anymore, and you could before, I would just do a valve adjustment! I bet that is it?
Old Feb 18, 2004 | 10:07 AM
GreenEX's Avatar
Default Re: (mattssi)
i was thinking i need a valve job but not b/c of vtec. i had cold air i new i couldnt hear it then so i put it to short ram b/c its a two piece intake. still couldnt hear it. is there a way i can do a check to see if it checks in.
Old Feb 18, 2004 | 12:24 PM
greebler's Avatar
Default Re: (H22CL)
Its not that noticable on a SOHC. Its at ~4500, it will start to hum louder.
hmmmm 45k HMMMMMMM
Old Feb 18, 2004 | 04:32 PM
91integraLSVTEC's Avatar
Default Re: (greebler)
take your intake tube off and drive around the block, you should hear vtec.. i remember when my intake tube fell off (dont ask me how that happen) my vtec was way louder..
