all motor not helpin me
If its a stock b20 block and head you CAN run a LS motor ecu but try and get the stocker B20 ecu for the OBD you happen to be running on your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeNice »</TD></TR><TR><TD CLASS="quote">You can get an LS ecu and chip it to have a bigger fuel curve because if you dont then you would have a 1.8 fuel map in a 2.0 motor and that is pointless.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1hotcivicSi »</TD></TR><TR><TD CLASS="quote">so if used a p28 then it would be good? or hmm i get confused
Ok....you need a B20 (which is NONvtec) ecu for the OBD 1 or 2 that your B20 motor is. Basically just find a B20 ecu that is obd2 (which I assume the motor you have is). What year is the motor you are recieving. And if you have a 00 Si then you want an obd2 motor and ecu for simplicity and for legality you want a 00 or newer motor...
</TD></TR></TABLE>Ok....you need a B20 (which is NONvtec) ecu for the OBD 1 or 2 that your B20 motor is. Basically just find a B20 ecu that is obd2 (which I assume the motor you have is). What year is the motor you are recieving. And if you have a 00 Si then you want an obd2 motor and ecu for simplicity and for legality you want a 00 or newer motor...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 »</TD></TR><TR><TD CLASS="quote">It is best to use the OEM ECU for your OBD B20....hands down. </TD></TR></TABLE>
Your post or question was answered along time ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk_Guy_N_S3DAN »</TD></TR><TR><TD CLASS="quote">
wnered
wnered
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blk_Guy_N_S3DAN »</TD></TR><TR><TD CLASS="quote">I don't think you can use the P28, because it's for VTEC engines only. Which I just
picked up from reading just now. Correct me if I'm wrong.</TD></TR></TABLE>
Yeah the p-28 is for vtec engines, but it doesn't sound as though this guy is going to use his b16 head? who knows, he didn't say
He is using his B20 longblock with a B16 head and he is asking if the stock Si ecu is usable for his new B20. I said it is not and needs to be a B20 ecu or at worst a chipped ECU that mirrors the B20 fuel maps...etc.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1hotcivicSi »</TD></TR><TR><TD CLASS="quote">oh nonoonoonnononno........ not using the b16 head haha i jsut want the b20 alone with the b16 tranny thats it </TD></TR></TABLE>
See above 2
See above 2
