20.0 x 6.0 x 14 M/T ET Drag Slicks mounted on 14" Steel Civic Rims
Old Feb 16, 2004 | 02:12 PM
D-Man's Avatar
Default 20.0 x 6.0 x 14 M/T ET Drag Slicks mounted on 14" Steel Civic Rims
*****sold**********
Modified by D-Man at 12:40 AM 2/22/2004
Old Feb 18, 2004 | 04:35 PM
D-Man's Avatar
Default Re: 20.0 x 6.0 x 14 M/T ET Drag Slicks mounted on 14" Steel Civic Rims (D-Man)
ttt
Old Feb 18, 2004 | 04:45 PM
vtekthis's Avatar
im'd you
Old Feb 19, 2004 | 06:48 AM
b20vtecEK's Avatar
Default Re: (vtekthis)
where are you located, are they the et streets??
Old Feb 19, 2004 | 07:56 AM
D-Man's Avatar
Default Re: (b20vtecEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtecEK &raquo;</TD></TR><TR><TD CLASS="quote">are they the et streets??</TD></TR></TABLE>
nope..ET Drags
Old Feb 19, 2004 | 08:55 AM
96dc2's Avatar
Default Re: (D-Man)
I didn't know they made a tube small enough. And don't they recommend not to use bead screws?
Old Feb 19, 2004 | 09:13 AM
D-Man's Avatar
Default Re: (96dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dc2 &raquo;</TD></TR><TR><TD CLASS="quote">I didn't know they made a tube small enough. And don't they recommend not to use bead screws?</TD></TR></TABLE>
Yep,one is available and who's "they" .The Tires are "Tube Type",it says so right on the sidewall.The Techs I talked to at M/T said it be a good idea to use tubes and screws cause they'll hold air longer,can be run at lower tire pressure and the tire is alittle safer cause it wont break the bead (at the expense of a little extra weight from tubes).They said even thou it says "Tube Type" you could run them without Tubes.They dont recommend bead screws if you run them Tubeless.....Next
Modified by D-Man at 1:33 PM 2/19/2004
Old Feb 19, 2004 | 10:39 AM
D-Man's Avatar
Default Re: (D-Man)
Old Feb 19, 2004 | 01:10 PM
D-Man's Avatar
Default Re: (D-Man)
Old Feb 19, 2004 | 11:11 PM
96dc2's Avatar
Default Re: (D-Man)
How low of PSI did you run?
Old Feb 19, 2004 | 11:37 PM
EG(6)SR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtecEK &raquo;</TD></TR><TR><TD CLASS="quote">where are you located</TD></TR></TABLE>
Old Feb 20, 2004 | 03:19 AM
D-Man's Avatar
Default Re: (96dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dc2 &raquo;</TD></TR><TR><TD CLASS="quote">How low of PSI did you run?</TD></TR></TABLE>
I didnt experiment much with them,I usually kept them around 12psi
Old Feb 21, 2004 | 12:41 AM
AdamBOMB_STi's Avatar
im very interested in buying your slicks, how soon do u want to sell them?
jdm_dc_fan
Sep 2, 2008 05:52 PM
97grnrs
Feb 28, 2008 06:00 PM
ReggieGrip
13
Jan 20, 2006 04:25 PM
7rrivera7
Jul 3, 2003 10:26 AM
