Mr. Gasket Exhaust cutout
Does anybody know a for sure answer to this. Some people say that the exhaust cut out won't work for OBD2. Does anyone have a for sure answer in regards to this? Thanks
well, it'd be kind of hard to put on on the rsx b/c you'd have to put the cutout before the cat in order to benefit from it at all, and unfortunately, the primary 02 is in the cat, so you'd throw a primary 02 sensor failure code, and your car would run horribly rich all the time.
i've been getting conflicting info on this as well..... i wanted to replace my cat with a straight pipe and cutout.... this would obviously throw a code for the 2nd o2 sensor...... the question is: what happens when that code is thrown?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team 4R »</TD></TR><TR><TD CLASS="quote">i've been getting conflicting info on this as well..... i wanted to replace my cat with a straight pipe and cutout.... this would obviously throw a code for the 2nd o2 sensor...... the question is: what happens when that code is thrown?</TD></TR></TABLE>
maybe something we'll have to find out
http://www.quicktimeperformance.com
Their cutout is called the QTEC. Check it out. I'd say it should work quite well. I've heard nothing but good from them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdRcrChk »</TD></TR><TR><TD CLASS="quote">http://www.quicktimeperformance.com
Their cutout is called the QTEC. Check it out. I'd say it should work quite well. I've heard nothing but good from them.</TD></TR></TABLE>
Thanks for the information
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swanny »</TD></TR><TR><TD CLASS="quote">The Mr. Gasket system sucks, I guess Quicktime Performance makes an electric cut out that is much better, </TD></TR></TABLE>
Just curious on why it sucks ?
Ya@inlinePRO
Apr 3, 2004 09:51 PM
