what kinda engine do i have?
im still not used to honda so im learnin...i know it is sohc...i wish i could show u a pic of it but no camera at the moment...is there neway u can tell me what kind of engine i got?
well hmm if it was an ex with would be the d16z6 but u say its not the orginal engine but has vtec and is only a sohc, it could be a jdm d15b but its prob just another d16z6 look on the block man
go the left of your exhaust manifold a couple inches, there should be some letters/ numbers printed on your block about 1.5 centermeters tall.
it should read something like this
D15
D16
and the rest are there...
D15
D16
do u have a sunroof??
if so its prolly a d16z6 sohc vtec
if theres no sunroof then you got the all mighty d15b sohc non vtec
either way put a turbo on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n3v3tz »</TD></TR><TR><TD CLASS="quote">by the way its vtech....</TD></TR></TABLE>
So you're engine is a phone?
vtec
It's probably a d16z6 if it's vtec. And those 16 things under the valve cover don't tell you anything about your engine except for it's 16 valve.
vtecIt's probably a d16z6 if it's vtec. And those 16 things under the valve cover don't tell you anything about your engine except for it's 16 valve.
To check your engine code, look at the block stamp. To find the block stamp, open your hood, and look down and to the left of your exhaust manifold. You should see this:
The 4- or 5-character code stamped onto the flat section is your engine code. You can see in the picture here that this engine's code is "B16A," which means that it is a JDM B16A engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n3v3tz »</TD></TR><TR><TD CLASS="quote">this mite sound stupid but ima say it neways...whenever i took off the valve cover there were 16 things in there (not sure what they are)...would that make it a d16??</TD></TR></TABLE>
Nope. The "16" part of "D16" denotes the displacement. D16 = 1.6L, D15 = 1.5L, B18 = 1.8L and so on. What you counted under the valve cover was the number of valves - your car has a 16-valve engine.
You probably have a D16Z6, which is the standard 1992-1995 Si, 1992-1995 Ex 4-door, and 1993-1995 EX engine.
Can you not just look on the block code as pictured above?
Also why are you removing the valvecover? I hope you have a new gasket and 4 sparkplug tube seals and a tube of Hondabond or else you'll have a topside oil leak.
Also be VERY careful not to overtighten the 10mm nuts on the valvecover because you will break the studs easily if you're not careful.
you change your V/C gasket and tube seals every time you pull your V/C???
I just changed my for the first time at 175k mi. and the seals were a LITTLE worn and the V/C was totally fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n3v3tz »</TD></TR><TR><TD CLASS="quote">thanks for the info on the block stamp...its a d16z6</TD></TR></TABLE>
that is the orginal engine your came with my friend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx »</TD></TR><TR><TD CLASS="quote">well hmm if it was an ex with would be the d16z6 but u say its not the orginal engine but has vtec and is only a sohc, it could be a jdm d15b but its prob just another d16z6 look on the block man</TD></TR></TABLE>
WHAT THE **** DID I SAY!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz »</TD></TR><TR><TD CLASS="quote">you change your V/C gasket and tube seals every time you pull your V/C???
that's what i'm thinking. i have pulled my valve cover probably 5 or 6 times this past month alone, and have not changed any of my seals or gaskets
so far so good, finds wood.
Jesus Christ do you realize that Honda says to change them every 30k miles?
Have you ever had a valve adjustment done?
I don't take chances, and for $12.00 worth of parts it's not like i'm wasting money to ensure a good seal on my valve cover.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">
Do you realize honda has a LOT of them and there's only one way to sell them?
It's very good quality rubber... I saved mine... I'll take a pic... it looked NO better or worse than the brand new one out of the honda bag...
I adjust my valves every 15k or so... it's not like removing the V/C causes some sort of trauma to the gasket... As long as it isn't dry or cracked and doesn't tear where you put rtv on by the cam hump it's fine...
And what exactly am I putting at risk? the V/C isn't pressurized... it's not like if the seal is leaking it's going to cause any more damage than ugliing up my a little.
I'm not saying never replace it but everytime you take off the V/C... that's a little extreme to say the least.
the only thing that was worn at all on mine (175k mi) was the tube seals... and they would've worked fine if I just rubbed them with a little oil... It's not like they were leaking or would've leaked...
Yeah, I've never had a problem with my VC gasket or seals.
I don't even use gasket maker/Hondabond on the corners usually.
And I pull my valve cover(s) at least once a month....I'm a busy body
