Looking to get a sway bars kit .... need opinions
Hi I own a 1995 Honda Civic Coupe
http://www.tracracing.com/isrc...=4462
Here is my actual suspension setup...
KYB AGX 4 corners
HR race springs
Front strut bar
Kumho V700 205/45/16 (50 TW)
( plan to get Jimfab traction bar )
Im not looking for a full road race suspension setup but I want to know if a good sway bar kit should be good for me or I should stay with my OEM front sway bar ??
Any advice are welcome !
Thanks
KYB AGX 4 corners
HR race springs
Front strut bar
Thanks
comptech rear all the way. best suspension mod you can get. they can be found for 350, but it's well worth it. search for comptech and you'll see mine and others 800000 posts about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">comptech rear all the way. best suspension mod you can get. they can be found for 350, but it's well worth it. search for comptech and you'll see mine and others 800000 posts about it.</TD></TR></TABLE>
Or get the ST rear sway for $125 at Summit and spend the amount you saved over the Comptech bar on something else worthwhile. If you don't autocross and road race in a professional manner, you won't notice the difference around town. The ST bar does a great job of neutralizing understeer and bringing the *** of the car around when you lift-throttle in a sweeping corner. That's all anyone wants out of a swaybar for street duty, so get the cheap, proven one over the expensive, proven one, IMO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo »</TD></TR><TR><TD CLASS="quote">thank to all of you ! I think I will get the suspension technique one... do you know a good place to get one ??? </TD></TR></TABLE>
http://www.Summitracing.com
If you live in their immediate shipping area you get overnight shipping at the normal shipping rate
I got mine from these guys they were awesome quick delivery and all..
http://www.lightningmotorsport...s.htm
does the ST rear sway bar endlinks go to the rear LCAs or does it mount to something else?
cuz i didn't realize the ST sway was that cheap..i was saving up for the SRR...hmmmm..sweet guys, sweet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heinz57 »</TD></TR><TR><TD CLASS="quote">does the ST rear sway bar endlinks go to the rear LCAs or does it mount to something else?
cuz i didn't realize the ST sway was that cheap..i was saving up for the SRR...hmmmm..sweet guys, sweet.</TD></TR></TABLE>
on the one that has the lower tie bar, the endlinks mount to the little un-used hole in your LCA.
sorry if this is thread jacking but what if your running ITR LCA's???? does the suspension techniques rear sway bar come with all the proper parts>? i was gonna put a stock gSR rear sway but how does it go into the subframe if its not threaded like the integras are?
Dunno how the ST bar connects but if it connects at the swaybar mounting points on the LCAs, it'll work fine with ITR LCAs.
8x1.25 locking nut or regular nut with lock washer on the other side of the subframe since they don't have welded nuts like Integras.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowoverheadcam »</TD></TR><TR><TD CLASS="quote">sorry to be OT but whats the diff between the integra type R rear sway and the suspension technique or comptech</TD></TR></TABLE>
i have a CTR sway at my house and compared it to my ST sway and the CTR has less bends but it the same thinckness(22mm).
hey the people with the st bar did u guys use any reinforcement??? i bought my bar used for dirt cheap but it didnt come with any reinformcent stuff or bolts, what kinda bolts do i use?? and for reinforcments just washers?? or should i look into the beaks kit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WangChung »</TD></TR><TR><TD CLASS="quote">i recently installed a ST rear sway/tie bar combo and it ****** sick! the car just begs to be in the twisties!
I have one of these waiting to be put one, damn winter go away.
</TD></TR></TABLE>I have one of these waiting to be put one, damn winter go away.
is there a chance of this being ripped from the sub frame?
I have heard numerous horror stories of sub frames being torn and I dont want that happing to me
Where'd you guys get the ST rear sway bar/tie bar combo? Summit doesn't seem to have the rear with the tie bar. Their site sucks when it comes to locating the correct part.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Egone »</TD></TR><TR><TD CLASS="quote">hey the people with the st bar did u guys use any reinforcement??? i bought my bar used for dirt cheap but it didnt come with any reinformcent stuff or bolts, what kinda bolts do i use?? and for reinforcments just washers?? or should i look into the beaks kit?</TD></TR></TABLE>
the strut/tie bar combo comes with reinforcements. thick billet aluminum blocks to reinforce the subframe.
