Anyone have any tips for getting a good luanch on the track?
Old Oct 10, 2001 | 10:05 AM
ArchAngel Sabastian's Avatar
New User
Default Anyone have any tips for getting a good launch on the track?
Just looking for pointers or anything you guys do you think helps.
[Modified by Sabastian, 11:12 AM 10/10/2001]
Old Oct 10, 2001 | 12:10 PM
LoudAccord's Avatar
Default Re: Anyone have any tips for getting a good launch on the track? (Sabastian)
put your tire pressure at 22psi.
Old Oct 10, 2001 | 12:12 PM
SOHCArchangel's Avatar
Default Re: Anyone have any tips for getting a good launch on the track? (LoudAccord)
rv to 4k gently gradually let the clutch out, then continue mashing, dont shift all hard, the secret is firm yet supple.....
Old Oct 10, 2001 | 01:10 PM
New User
Default Re: Anyone have any tips for getting a good launch on the track? (SOHCkordVTEC)
thnx all
ill post times tonite
Old Oct 10, 2001 | 02:00 PM
LoudAccord's Avatar
cool... what mods do you have?
Old Oct 10, 2001 | 03:26 PM
New User
22psi? i have a set of toyo's usually at 44 psi.
Old Oct 10, 2001 | 03:27 PM
LoudAccord's Avatar
yep 22
Old Oct 10, 2001 | 06:36 PM
Gennady's Avatar
New User
I wish I had the power to break loose my 7.5 inch thick tires. Even with torque breaking (auto tranny). I keep mine at 40psi. They say that 44 is the max, so I dont take it to the limit.
Old Oct 10, 2001 | 06:40 PM
4doorH22's Avatar
Quoting myself from my answer over in the competition forum:
There are so many different combinations of cars, tires, and surfaces that there is no one way to do it. With four bangers that make their power high in the rev range, the goal is to spin the tires on launch, and have them hook up as your engine is entering the meat of it's torque curve. Once you're hooked up you'll be putting power to the ground through your motor's power peak. On each upshift, you want your RPMs to fall around your peak torque, no higher. So depending on your engine's torque curve, it's not always the fastest way to run the 1/4 mile bouncing off the rev limiter in each gear.
Old Oct 10, 2001 | 06:46 PM
4doorH22's Avatar
You want high PSI like that for say a road circuit or auto crossing. Basicaly less sidewall deformation and tire squirm for crisper, tighter handling, transient response, all that. It's also okay on the street and can increase gas milage, at the expense of (maybe) some abnormal tire wear.
On the drag strip, you want low pressure (like the mentioned 22 PSI) so your tires just sag and basically put more rubber/surface area on the track. Any top fuel drag car you see on tv has saggy, deflated tires. Run the 1/4 mile with any more than 27~30 PSI and you'll be spinning like you're on ice (with an aggressive enough clutch drop). Oh well, I guess you're already at the track...
Old Oct 10, 2001 | 07:51 PM
New User
Default Re: Anyone have any tips for getting a good launch on the track? (4doorH22)
R/T 1.365
60 2.571
330 7.054
1/8 10.806
MPH 65.06
1000 14.040
1/4 16.760
MPH 82.72
best run shittest reaction..?
i ran at 29psi
made the mistake of filling up too
[Modified by Sabastian, 8:52 PM 10/10/2001]
Old Oct 10, 2001 | 08:05 PM
4doorH22's Avatar
That's about right. The best a full interior F22 Accord with bolt ons will do is low 16s. 15s with weight reduction and/or internal engine work.
Old Oct 10, 2001 | 08:48 PM
John's Avatar
New User
or a 14.02 with the magical blue bottle (yes on an F22B1)...
:wink: :wink:
Old Oct 10, 2001 | 08:58 PM
accordking's Avatar
Default Re: Anyone have any tips for getting a good launch on the track? (DunReit)
This may sound a little tricky, but here it goes.
When you trigger the second staging light rev your engine-3-4k(depending what your set up is).
Pull your E-brake as high as you can.
Let off the clutch slowly till the clutch starts to grab.
Then, when the light turns green lay into the gas and at the same time drop the e-brake.
[Modified by accordking, 9:58 PM 10/10/2001]
Old Oct 10, 2001 | 09:22 PM
smokin rubber's Avatar
Default Re: Anyone have any tips for getting a good launch on the track? (accordking)
I was at the local 1/8 today and managed some pretty decent times
rt 0.545
60' 2.341
mph 68.3
et 10.260
that is as good as I can get for now. most runs I hit 66-67 at between 10.3-.7
I lanch pretty consertively and stomp it until the shift lite comes on.
There was a 98-99 accord there with a supercharged H22 that ran a best 9.55 at75
He couldnt get the tires to hook up. I run 14's at the strip at 25r-28l. psi
[Modified by smokin rubber, 1:23 AM 10/11/2001]
Old Oct 10, 2001 | 09:53 PM
4doorH22's Avatar
Default Re: Anyone have any tips for getting a good launch on the track? (smokin rubber)
14s what? Quarter mile?
A 14 second quarter should have you in the mid 9s on the 1/8th.
Old Oct 10, 2001 | 09:58 PM
sorry I mean 14 inch rims for the drag strip. I wish I could run 14s
924doorEG
Feb 17, 2008 08:52 PM
4Dinsaneb16
15
May 10, 2007 06:33 PM
BauleyCivic
Aug 14, 2003 10:10 AM
raene
Oct 2, 2002 05:40 AM
SoulSurfer
Jun 25, 2002 04:22 PM
