can a SI TRANNY be bolted onto a standard motor using the stds axles?
Old Feb 15, 2004 | 09:29 PM
Gant's Avatar
Default can a SI TRANNY be bolted onto a standard motor using the stds axles?
hey guys well im pretty sure my input shaft bearing on the new std hatch i just bought is toasted, my question is my friend has a spare Si tranny from a crx. will everything bolt right onto the std? including shift linkage/axles. etc? can i just use the clutch from the standard tranny?
Old Feb 15, 2004 | 11:37 PM
Louie B.'s Avatar
Default Re: can a SI TRANNY be bolted onto a standard motor using the stds axles? (Ba4)
In a word... Yes, and you'll have much better gearing.
Use the STD's axles and shift linkage.
However, you'll need to find out the year of the tranny.
If it's an 88, You'll need an '88 clutch, pressure plate, and flywheel (you can use a 90-91 PP & Flywheel if you use an 88 accord clutch disk) The easiest way to tell an 88 is to count the # of splines on the input shaft (88 = 21 spline, 89-91 = 20 spline)
If it's an 89, do yourself a favor and use a 90-91 clutch, PP & flywheel (212mm clutch disk as opposed to 200mm)
If the tranny is a 90-91, obviously use the 90-91 clutch kit.
The year of your STD doesn't matter, the year of the tranny is the determining factor.
Old Feb 16, 2004 | 02:12 AM
Gant's Avatar
Default Re: can a SI TRANNY be bolted onto a standard motor using the stds axles? (thumpu77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumpu77 &raquo;</TD></TR><TR><TD CLASS="quote">In a word... Yes, and you'll have much better gearing.
The year of your STD doesn't matter, the year of the tranny is the determining factor.</TD></TR></TABLE>
u said 89-91 has 20 splines so how do u know exactly which ones are 90-91 and whicih ones are 89?
Old Feb 16, 2004 | 06:34 AM
Louie B.'s Avatar
If you look at the tip of the input shaft (the part that would slide into the pilot bearing) you will see a single groove cut around the circumfrence on the 89's, 90-91 will have 2 grooves.
Either way shouldn't matter, I'd still use the larger 90-91 clutch kit & flywheel. If your car is an 89 and you want to go cheap and not replace the clutch (not recomended) or re-use your flywheel and just get a new 89 clutch kit, then you're still ok using an 89-91 tranny.
Edit: I thought I had a picture of my 89si shaft so I could show you, but this is the only one I could find.... doesn't do you much good, does it.
Old Feb 16, 2004 | 04:49 PM
Gant's Avatar
thanx thump.. my car is a 90 std hatch, i really dont want to spend money on a clutch or flywheel cuase im saving for a motor but my friend has a spare si tranny that i can put on. in the cheap way can i reuse my 90 clutch flywheel IF the tranny is 90-91?,
Old Feb 16, 2004 | 05:27 PM
1CiViC1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">can i reuse my 90 clutch flywheel IF the tranny is 90-91?, </TD></TR></TABLE>
yes, i used my oem clutch from my d15b1 when i swapped in the a6 tranny. works perfect
Old Feb 16, 2004 | 05:34 PM
Gant's Avatar
basicly thump can i just throw in the tranny and thats it? i really dont want to get a new clutch kit is it possible at all?
Old Feb 16, 2004 | 06:07 PM
Gant's Avatar
Default Re: can a SI TRANNY be bolted onto a standard motor using the stds axles? (1CiViC1)
tran<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1CiViC1 &raquo;</TD></TR><TR><TD CLASS="quote">
yes, i used my oem clutch from my d15b1 when i swapped in the a6 tranny. works perfect </TD></TR></TABLE>
so my car is a 90 any 88-91 a6 tranny would work? on my stock clutch and flywheel? or just the 90-91 a6 tranny?
Old Feb 16, 2004 | 06:11 PM
EG8R's Avatar
88 won't work. 89-91 will work
Old Feb 16, 2004 | 06:14 PM
Gant's Avatar
Default Re: can a SI TRANNY be bolted onto a standard motor using the stds axles? (skelly ed6)
ok cool my friend is pretty sure the extra si tranny he has is 90-91, so everythings ready to rock? direct replacment i can resuse everything from clutch and flywheel to axles correct?
thanx for all ur help guys i know i shoulnt use the same clutch but im saving for the motor and i really dont want to spend any money on this car unless its for the motor.
Old Feb 16, 2004 | 06:58 PM
Gant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 &raquo;</TD></TR><TR><TD CLASS="quote">ok cool my friend is pretty sure the extra si tranny he has is 90-91, so everythings ready to rock? direct replacment i can resuse everything from clutch and flywheel to axles correct?
just need confirmation on this thanx guys
-chris
Old Feb 16, 2004 | 08:40 PM
Louie B.'s Avatar
-chris</TD></TR></TABLE>
consider it confirmed... if it's 89-91 you're good to go!!
Old Feb 16, 2004 | 08:50 PM
Gant's Avatar
thanx guy id like to thank all of you for ur help i really appericate this board.
im gonna do the tranny swap this month, and replace the axle seals in them, my friend yanked them out cause he was practicing how to put them in. thanx for all ur help again guys.
-chris
Old Feb 17, 2004 | 11:01 AM
subgeniusdude's Avatar
So no need to swap hubs,std axles fit the Si trans?
Old Feb 17, 2004 | 01:33 PM
MonkeyMagic's Avatar
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by subgeniusdude &raquo;</TD></TR><TR><TD CLASS="quote">So no need to swap hubs,std axles fit the Si trans?</TD></TR></TABLE>
That is correct
Old Feb 17, 2004 | 03:01 PM
Default Re: Re: (MonkeyMagic)
cr-x-91
Sep 10, 2007 09:17 PM
GreenBean
13
May 27, 2005 11:09 AM
brent_G
Oct 7, 2003 07:52 PM
It's*BOLO!!
May 10, 2003 05:24 AM
KevronsEG
Jan 14, 2003 08:48 AM
