axles wont go in all the way! zc crx swap
Old Feb 15, 2004 | 09:07 PM
kanzenr91si's Avatar
Default axles wont go in all the way! zc crx swap
just got done, or so i thought, swapping my zc into my 91 crx si and neither axle will seem to go in all the way. i used my stock si tranny and axles. could there be something inside? i really dont want to pull the suspension again, so if anyone can help me out asap i would really appreciate it.
by the way, both axles are about the same length away from the tranny.
Old Feb 15, 2004 | 09:42 PM
c0nspire's Avatar
Default Re: axles wont go in all the way! zc crx swap (kanzenr91si)
did you try to tap it in by hitting the flange? you hafta tap it in because of the c clip.
jsut an idea.
Old Feb 16, 2004 | 12:22 PM
89b16hf's Avatar
try taking off the dust shelds on the spindels
Old Feb 16, 2004 | 12:26 PM
civickiller's Avatar
Default Re: axles wont go in all the way! zc crx swap (89b16hf)
if you are putting back in the stock si tranny with the stock axles, theres not need to take off your dust shield because they should fit. do like the other guy said and tap lightly with a hammer
Old Feb 16, 2004 | 01:29 PM
TheApexHunter's Avatar
I had to hammer mine in back in the day when I did my ZC swap
Old Feb 16, 2004 | 02:34 PM
CRXRageD's Avatar
try using a hammer and small 2x4. it will work.
onefiine69
22
Mar 29, 2005 06:34 PM
onefiine69
Mar 14, 2005 06:03 AM
onefiine69
Mar 12, 2005 05:08 PM
mateencrx91
Nov 11, 2003 02:02 AM
