s1 tranny?
Old Feb 15, 2004 | 08:46 PM
speed_racer012's Avatar
Default s1 tranny?
Did a bunch of searching and couldn't find what I wanted. I'm just looking for specs on the s1 tranny? I Thought that I heard that it has pretty short gears but that is about it. any and all other specs are appreciated.
Old Feb 15, 2004 | 08:52 PM
VtecKiDD's Avatar
Default Re: s1 tranny? (speed_racer012)
same gearing as the 96 type-r, 2nd shortest gear ratio in b16 land, 92-93 GSR ys1 is the closest ratio cable tranny out there
Old Feb 15, 2004 | 08:53 PM
Default Re: s1 tranny? (VtecKiDD)
is it a pretty good tranny though?
Old Feb 15, 2004 | 08:57 PM
Deetz's Avatar
Crazy Honda Guy
Its the most common JDM cable tranny out there and are good quality. The downside some are known to have grinding problems from abuse, and replacement parts not to be had no North America.
Modified by Deetz at 11:12 PM 2/15/2004
Old Feb 15, 2004 | 09:00 PM
blueintegra90's Avatar
i liked my s1 tranny untill i blew the diff and the back of the housing off but overall i guess thats with any tranny.http://www.allmotorhonda.com/t...s.htm there is a chart of gearing.
Old Feb 16, 2004 | 12:34 AM
Sleepin Crx's Avatar
Default Re: s1 tranny? (blueintegra90)
i have an s1 tranny in my b16'd crx
its a good tranny but every tranny has a downside
pros
- very short gears
- awesome for running on the stret, if thats your cup of tea since it accels FAST
cons
- eventually your 2nd, 3rd and 4th will start to grind and mess up, all b series cable trannys are notorious for this
- very very bad for the highway and highway pulls(100kms/h = 4000rpm in 5th)
- bad on gas since the revs will always be high
if short gearing is ur thing, u cant go wrong BUT they syncros WILL go out on you
my 3rd is gone and my 5th pops out of gear in the highway every like 5 kms, its annoying as hell
Old Feb 16, 2004 | 07:08 AM
regime's Avatar
Default Re: s1 tranny? (Sleepin Crx)
to the guy that has 5th gear pop out. check yer tranny fluid. make sure its full and hell just change it. it cant hurt.
but neways i love the s1 tranny... other then the syncros...
final 4.4
1st 3.23
2nd 2.105
3rd 1.458
4th 1.107
5th .848
143mph at 8200 rpm... in a theoretical program that is.
Old Feb 16, 2004 | 10:33 AM
SiRex91's Avatar
Default Re: s1 tranny? (regime)
I love the short gears of my S1. It's really nice on the road course for coming in and out of turns, but it sucks for long drives on the highway. I'm either gonna switch to a hydro JDM ITR trans or replace the synchros in my S1 and also pop in a LS 5th gear.
Old Feb 16, 2004 | 10:59 AM
haggar's Avatar
Default Re: s1 tranny? (SiRex91)
Hmm, aren't some LS trannys S1's also... My 1990 LS trans is an S1, so just make sure you know what you are getting..
Old Feb 16, 2004 | 11:14 AM
SiRex91's Avatar
Default Re: s1 tranny? (haggar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haggar &raquo;</TD></TR><TR><TD CLASS="quote">Hmm, aren't some LS trannys S1's also... My 1990 LS trans is an S1, so just make sure you know what you are getting..</TD></TR></TABLE>
Yes they are. Make sure that you get the JDM S1 trans. There is a big difference!
Old Feb 16, 2004 | 12:12 PM
Robb's Avatar
What are the options for replacements parts for this tranny?? The jdm S1.
Old Feb 16, 2004 | 12:18 PM
SiRex91's Avatar
Default Re: s1 tranny? (Robb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robb &raquo;</TD></TR><TR><TD CLASS="quote">What are the options for replacements parts for this tranny?? The jdm S1.</TD></TR></TABLE>
You can get rebuild kits from JDM_DOHC_SIR on this board.
Old Feb 16, 2004 | 02:34 PM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepin Crx &raquo;</TD></TR><TR><TD CLASS="quote">- very very bad for the highway and highway pulls(100kms/h = 4000rpm in 5th)
Im not sure of the conversion but doing 80mph im at 5000rpm
Old Feb 16, 2004 | 05:48 PM
Default Re: s1 tranny? (Smokinsax)
Well at 80 with my d15b w/o vtec with si tranny i'm at least at 5000
Old Feb 19, 2004 | 08:46 PM
going 100km/hr or for u US guys 60mph in 5th i do 4000rpm
turboef90
Transmission & Drivetrain
May 5, 2013 12:19 PM
ACrite3404
Sep 21, 2005 06:56 AM
shawn_crx
Aug 17, 2005 02:49 PM
brent_G
Oct 2, 2002 05:56 PM
turboex
Jul 21, 2002 03:37 PM
